Activity Forums Apple Final Cut Pro Legacy New to Mac & FCS2 – Help with Compressor
  • New to Mac & FCS2 – Help with Compressor
    Posted by Derek Tow on August 10, 2009 at 2:01 am
    Hi – here is my situation. I am an Adobe guy but wanted to try a MAC and FCP so I bought a used G5 online loaded with FCS2 but without disks which I knew and accepted the risk.
    Everything works well expect Compressor will not load. I attempted to register the software with Mac and it seems to have taken as it shows the license number.
    I need to reload Compressor somehow as all troubleshooting has failed. Can’t upgrade to FCS3 as the G5 isn’t an Intel.
    Questions:
    1. Can I borrow disks from someone – reload just compressor and use the registration code FCS shows?
    2. Or do I need to buy an unregistered copy of FCS2 and load it fresh? Since I can’t upgrade to FCS3 on this machine – I could just get an academic version.
    3. Are there any other options?
    Thanks for any advice.
    Derek
    Derek Tow replied 17 years, 1 month ago 2 Members · 2 Replies
  • John Fishback
    August 10, 2009 at 2:56 pm
    Here are a couple of links that might help.
    https://support.apple.com/kb/TS1888?viewlocale=en_US
    https://www.digitalrebellion.com/compressor_repair.htm
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Derek Tow
    August 11, 2009 at 2:06 am
    Great suggestions – thanks. I’ll give them a try. If no luck, I’ll buy the software and reinstall.
    Derek
