Activity › Forums › Apple Final Cut Pro Legacy › new to FCP…need help with gunshot effect
  • new to FCP…need help with gunshot effect
    Posted by Drew Richards on August 19, 2008 at 3:57 pm
    New to FCP and am trying to add a gunshot effect to a short film. Doesn’t have to look top notch…just looking for something simple.
    I added a muzzle blast for the shooter from detonationfilms.com, which worked great. When i overlayed the muzzle blast, the background was black. I was able to fix this by using Modify>Composite>Screen.
    Now I’m trying to add the bullet hitting the victim, but all the shots from detonationfilms.com have white backgrounds. For some reason, when I go to Modify>Composite>Screen it doesn’t work for white. What I’m I missing? Are there any other websites that have bullet hits with a black background? As I said, I’m not too picky.
    Lastly, I have about a 40 frame shot of the victim collapsing to the ground after being shot. He’s wearing a white T-Shirt, which I’d like to stain with blood. Can someone tell me what program would work best for this? I basically think I need to go frame by frame and “paint” the blood on him, but not sure what program is best for this (and simple).
    Thanks! Much appreciated.
    Tom Wolsky replied 18 years, 1 month ago 5 Members · 4 Replies
  • Jeremy Garchow
    August 19, 2008 at 5:26 pm
    Sounds like a job for After Effects:
    https://www.videocopilot.net/products/action/
  • Ryan Mast
    August 19, 2008 at 7:08 pm
    Different composite modes do different things. Using “Screen” worked with the muzzle blast because that takes just the light areas and applies them to the underlying track. Check out this page for more info about what different composite modes do:
    https://www.kenstone.net/fcp_homepage/basic_composite_mode.html
    For their blood spurt, I’d recommend using the Chroma Keyer to key out the white areas and change it to the “Normal” composite mode. Might need to tweak it with the Color Corrector, too, to make it match the rest of the frame. Adjust to taste.
  • David Bogie
    August 19, 2008 at 8:11 pm
    The same thread has also appeared at apple.com. Similar advice given: After Effects.
    bogiesan
  • Tom Wolsky
    Try Composite mode Multiple with the white background or one of the others.
    Try a not too red, more dark, color matte for the shirt. Use a garbage matte to make the shape and a composite mode and/or opacity to blend it with the shirt.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
