New to FCP X 3 Questions – duplicate, audio, original file cut off
1. I can not seem to duplicate a project correctly. It is a Multicam project. When I duplicate or duplicate as snapshot, then try to edit the new file, the original file is changed. I want to edit a new file without messing with the original.
2. Does anyone know why the audio is so much lower in FCP? I used Vegas for years and had my recorded audio (Using Blackmagic Hyperdeck studio 2 and studio Pro) just right. The peaks would run at about -3 to -6 db. When I pull the same data into FCP I have to raise the volume by 12db to get the same output.
3. I have 2 clips recorded on a Blackmagic unit onto an SSD drive. (2 clips because they run out of record time on one clip around and hour or so) I used to edit in Sony Vegas and had no issues with the clips going together seemlessly. FCP X seems to cut off the final second (or less) of the first clip.
Thanks for the help!
