Activity Forums Apple Final Cut Pro Legacy New To FCP 4!
  • Posted by Smallfry on July 19, 2005 at 10:57 pm
    I’m new to FCP 4, fresh from Media 100. I bought a Matrox RT Mac capture card and BOB. Now I am unable to capture video from my Beta SP or DVC Pro decks. How can I route a firewire drive into these two without ports?? I was trying version 3 and it had multiple options for capture, but the version 4 has only a couple. Any tips??
    Smallfry replied 21 years, 2 months ago 3 Members · 5 Replies
  • Walter Biscardi
    July 19, 2005 at 11:33 pm
    If you making the move from Media 100 the best advice I can give you is to run the Tutorial and read up on the Capturing section of the manual. That’s what I did when I made the switch from M100 four years ago. Capturing is quite a bit different than with M100.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Smallfry
    July 20, 2005 at 12:13 am
    Thanks for the tip and I will read the tutorial. However, my question is do I need another piece of hardware to capture from my Beta deck and DVC pro deck. The options are not extensive in version 4.
  • Walter Biscardi
    July 20, 2005 at 11:25 am
    If you want to capture uncompressed from your Beta deck, then you will require additional hardware such as the AJA Io, Aurora Pipe series or the AJA Kona series. You’ll also need fast harddrives.
    If you are going to capture using the DV codec, then you can run the Beta machine through the DVCPro deck and just capture via Firewire.
  • Paul Nevison
    July 20, 2005 at 12:46 pm
    the RT Mac card you have purchased does not work with any versions of FCP 4 or later. i would suggest asking for a refund from whoever you bought it from – sounds like a dodgy vender that would sell a product that is no longer supported or sold by the manufacturer (Matrox)!!!
  • Smallfry
    July 23, 2005 at 3:43 pm
    OK, what is a reasonable solution within a tight budget to get the job done??
