Activity › Forums › Adobe After Effects › New to AfterEffects, animation and playback
  • New to AfterEffects, animation and playback
    Posted by Conor Farnaby on September 29, 2017 at 9:54 am
    So I’m new to AfterEffects and am struggling. I’m trying to put in titles and also need to animate them. Is there a way to make these titles and animate them and put them straight into PremierePro or is there an easier way to do it all in AfterEffects? Additionally, when I’m trying to watch the video so I can get to the right point for the titles, it goes in slow motion. any help that can be offered will be greatly appreciated.
    Conor Farnaby replied 8 years, 11 months ago 3 Members · 6 Replies
  • Daniel Waldron
    September 29, 2017 at 12:59 pm
    What type of animation are you trying to do? If it’s simple, you could probably just do it in Premiere. To answer your other questions, read up on dynamic link and RAM previews.
  • Conor Farnaby
    October 2, 2017 at 8:24 am
    Hi Daniel,
    I’m needing to animate text on a custom path, do you know of anyway for me to this?
    Additionally, thank you for the links ☺
    Conor
  • Daniel Waldron
    October 3, 2017 at 3:06 pm
    No problem! Here is a basic video showing how to animate text on custom paths.
    https://www.youtube.com/watch?v=2EHnGKmf1-s
  • Remus Hosu
    October 8, 2017 at 6:14 pm
    Hi Conor,
    If you’re new to AE, then maybe the fastest solution for you is to use the Text presets from the Adobe Bridge. Select the text layer and then go to File-Browse in bridge, then just select a text effect you like. You can then render out the texts individually as MOVs with transparency and import them in Premiere. Settings for MOV with alpha: Composition-Add to render queue. Output module-format Quicktime, format options PNG. Set the color channel to RGB + Alpha. Next, click next to output to, to set the destination path of your file and click render. Hope this helps
    https://bluefx.net
  • Conor Farnaby
    October 9, 2017 at 8:01 am
    Thank you so much! This is really helpful and managed to get me to do my work, so thank you!
  • Conor Farnaby
    October 9, 2017 at 8:03 am
    Hi Remus,
    That’s amazing thank you so much! This has helped me get my work done so thank you! ☺
