Activity Forums Adobe After Effects New to AE from Combustion
  • New to AE from Combustion
    Posted by Dave Potts on January 9, 2006 at 7:26 pm
    Hi All,
    I’m trying to expand my skills by adding AE to my arsenal, I’m currently a Combustion user. I have three quick questions that you might be able to help me with:
    Is there a way to view your comps from a custom perspective (3d view) and rotate around in the comp window as you are working?
    Is there a way to easily replace footage or stills once they are loaded into a comp? (Switch one object for another)
    Can you work from inside the project flowchart view, or is this just for an overview?
    I appreciate any help anyone can give. Thanks!
    German Rubio replied 20 years, 8 months ago 3 Members · 2 Replies
  • Todd Gillespie
    January 9, 2006 at 10:18 pm
    [Dave Potts] “Is there a way to view your comps from a custom perspective (3d view) and rotate around in the comp window as you are working?”
    yes, under the active camera pull down -custom view (but the layer needs to be 3D first)
    [Dave Potts] “Is there a way to easily replace footage or stills once they are loaded into a comp? (Switch one object for another)”
    Yes, rt click on any file, footage,etc “replace footage”
    [Dave Potts] “Can you work from inside the project flowchart view, or is this just for an overview?”
    This one I’m not so sure of… I don’t believe so, I think is just a graphical chart, but not a workable interface.
    Good Luck,
    Todd at UCSB
    Television Production
  • German Rubio
    January 11, 2006 at 10:14 am
    If you wanna change a file from a finsihed comp and u want to mantain all the properties and keyframes, u must select the itemm on the comp and then, drag the new file over it while u mantain the ALT pressed. That way, u will replace a file, for example to make a duplicate comp, leaving the ohter before the same.
    I use it when i have to make diferent composition to make a render qeue in a row.
    Hope that u can understand my english!!!
