Activity › Forums › Apple Final Cut Pro Legacy › New system should raid be inside or outside the Mac?
  • New system should raid be inside or outside the Mac?
    Posted by Steve Garman on May 21, 2007 at 10:34 pm
    We’re building a new FCP Studio 2 system with the Mac 8-core and I’m wondering what the pros and cons are of building the raid inside the box or outside the box. The Mac Pro seems to invite the internal raid but in the past, outside raids were all we ever considered. Maybe it’s just becuase there wasn’t enough space before. What do you think?
    BTW thanks very much for helping out an FCP newbee!
    Walter Biscardi replied 19 years, 4 months ago 5 Members · 4 Replies
  • 13 Create COW Profile Image
    13
    May 21, 2007 at 11:09 pm
    It will work just he same ether way. Its just easier to do it internal because you don’t have to have a external enclosure and cables running to the computer.
  • Jerry Hofmann
    May 21, 2007 at 11:10 pm
    Inside it’s less expensive, but limited to the number of drives you can put in there…
    Outside it’s portable (depending) but costs more because you need to have an enclosure. However you can have a LOT faster array externally, and can choose a RAID 5 for protection of the data… you lose a drive in a RAID 0 and you lose everything on all drives.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Eric
    May 22, 2007 at 8:58 am
    we use 3 striped wd 500 GB in our mac pro. fantastic speed, easy setup (20 min), and cheap!
    Do backup your data on external FW drives = Fast, Safe & Cheap !!
    we have over 200 MB/sec with an empty raid
    we have over 180 MB/sec with 50% full
    we have over 130 MB/sec with 10% left
    with some tricks you can even use 4 drives (I heard) = even faster
    if you need more speed for your projects, consider a very good external raid solution, you can afford it!!
  • Walter Biscardi
    May 22, 2007 at 9:58 am
    I always recommend external enclosures because I feel they’re more easily expandable, more flexible and in the case of a total system failure, can be moved to another system to keep working.
    We’ve been using SATA for the past year or so and are considering switching back to Fibre Channel to bring our two rooms together with networked storage.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
