Activity Forums Adobe Premiere Pro New System Configuration for Premiere Pro
  • New System Configuration for Premiere Pro
    Posted by Akbar Basha on July 6, 2011 at 11:22 am
    Am planning to build a new editing system with the following configuration, please help me weather its a good combination for video editing especially for Adobe Premiere Pro.
    Intel Core i7 2600K
    Asus P8Z68V-Pro
    Corsair DDR3 2x4GB (Since 2600K supports only dual channel)
    WD HD 1TB
    And I already have a Radeon HD 5700 Graphics Card (Which doest support ATI STREAM)
    Akbar
    Akbar Basha replied 15 years, 1 month ago 3 Members · 5 Replies
  • Chris Knight
    July 6, 2011 at 12:51 pm
    You will need at least one additional hard drive, as common practice dictates that you should not use your OS/applications drive to store your media on. This shouldn’t be too costly, as a 1TB drive is under $60 these days. If you can afford it, replace the ATI card with a 1GB+ FERMI nVidia card (it will speed up workflow in Premiere).
  • Akbar Basha
    July 6, 2011 at 6:15 pm
    Thank you Chris, I ll be buying the nVidia card a couple of months later and Hard Drive I can get one more (Any spefic Hard Drive you would like to prefer? And how about striping it?). Other than that should I concentrate on any particular memory or motherboard..??
  • Alex Gerulaitis
    July 6, 2011 at 6:45 pm
    It’s a well balanced motherboard with the right chipset – I think you in good shape with it, especially if you use DDR3-1600 or faster memory.
    I 2nd Chris’ advice on getting a separate media volume: the most common configuration (for that volume) is 2 drives in RAID0. If your workflow is fairly low-bandwidth (no multiple streams, no uncompressed or high bandwidth files) – a single media drive is fine. For internal drives, Hitachi 7K series are decent; WD Black Caviars are good too although WD doesn’t qualify them for RAIDs.
    Alex (DV411)
  • Chris Knight
    July 6, 2011 at 6:55 pm
    I always recommend Samsung’s 1TB F3 drive. I’ve bought over 100 of them in the last two years, and only one was DOA. Crazy fast in a RAID0 config, and still very fast by itself.
  • Akbar Basha
    July 10, 2011 at 7:11 am
    Thank you friends.. Am going to setup Raid 0 with WD RE4 Hard Drives.. Thanks for your valuable suggestions.
