Activity Forums Apple Final Cut Pro Legacy New SHARE Problem
  • New SHARE Problem
    Posted by Jon Felix on September 23, 2009 at 9:43 pm
    Arrgh! More SHARE problems (see my earlier posts). This time when trying to upload to YouTube I get: Share Failure. An internal error occurred: Apple Qmaster File Agent not found.
    Any ideas?!
    Jon Felix
    DIGIT POST
    Marin County, California
    Kevin Monahan replied 17 years ago 4 Members · 6 Replies
  • David Bogie
    September 24, 2009 at 3:10 pm
    Yar, I get that, too.
    I’ve decided Share is useless so I don’t even bother with the menu any more.
    Someday they’ll fix it, maybe.
    Be sure to fill out a form and drop it in the FCP FEEDBACK folder at apple.com.
    https://www.apple.com/feedback/finalcutpro.html
    bogiesan
  • Vashi Nedomansky
    September 24, 2009 at 4:48 pm
    My share option also has never worked. Failed message. Read somewhere that if you have a quickcluster activated with your multicores then Share is disabled or just plain won’t work.
  • Kevin Monahan
    September 24, 2009 at 7:21 pm
    Works fine for me guys. Don’t know what else to say.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • David Bogie
    September 24, 2009 at 7:46 pm
    I’ve been playing with SHARE all morning. About half of the options work for half of my projects. Results are utterly inconclusive.
    However, Flip4Mac may be part of the problem in may case. If I encode a 60 second piece from a DV timeline to full size WMV using just my old first gen Intel, it finishes in about 8 minutes. If I use my machine as as cluster, using Flip4Mac, the same file can take up to 20 minutes.
    Going to other formats seems to actually benefit from a cluster but they also sometimes stop or never get started.
    So…hardware on my end?
    bogiesan
  • Jon Felix
    September 24, 2009 at 8:11 pm
    “…. quickcluster activated with your multicores …” Desperate for a solution as I am, I have no idea what you’re talking about 🙂 I’m an editor, not a computer tech, is there a solution out there for us humble editors?!
    Jon Felix
    DIGIT POST
  • Kevin Monahan
    September 24, 2009 at 10:06 pm
    There’s got to be a conflict with your Qmaster settings or another program. Sorry I can’t be more helpful.
    Kevin Monahan
