Activity Forums Apple Final Cut Pro Legacy New question – FCP 7 worth learning at this point? Or should I just jump to Premiere?
  • New question – FCP 7 worth learning at this point? Or should I just jump to Premiere?
    Posted by Stephanie Joan on May 13, 2012 at 12:41 am
    I’m sure this topic has been discussed to death, but I wasn’t able to find an answer to this specific question. I’m just getting started in editing – having done audio for a few years now – and I’ve been working in Final Cut Pro X. I’m really feeling the limitations in this version, and I’m thinking that Final Cut Pro 7 would likely allow me more freedom to do what I need to do. I’m wondering, is it worth learning 7, since it will just be phased out? The other option is moving over to Premiere. If X really as limited as it feels? Is Premiere going to be the most professional NLE going forward?
    Would love to hear your thoughts on this. Also, if there’s already an answer to this somewhere on the board that I could not find, please feel free to point me there.
    Stephanie
    https://www.theculinarylife.com
    Neil Patience replied 14 years, 3 months ago 4 Members · 5 Replies
  • Rafael Amador
    May 13, 2012 at 10:14 am
    Hi Stephanie,
    I’ll keep working with FC for a while, but at this stage i wouldn’t recommend nobody start learning FCP.
    Little by little i will migrate to PP that is the most natural route for people having worked with FCP, most of all after the last CS6 release.
    Some people say that the new PP CS6 is FCP.8.
    Have a look here: https://forums.creativecow.net/finalcutprox
    You will find many interesting insights regarding FCPX and PP.
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    May 13, 2012 at 3:18 pm
    Depending on your hardware.
    With FCP7 it will not run on future Macs.
    So there is an end of life.
    If your in it for the long haul. Make the switch, go with something that will be around and can utilize the latest hardware. This will make editing easier, better, faster and allow you to hone your skills and grow and develop with an app.
    JM2C
    Chris Tompkins
    Video Atlanta LLC
  • Neil Patience
    May 13, 2012 at 3:45 pm
    I have to agree with Rafael’s answer but with one caveat.
    I would say it depends on what you want to do and the environment in which you work.
    If you are buying the software, for you, to run in your own business then to invest in FCP7 now, as Rafael says, is really pretty pointless. The two main non FCP options as alternatives are Avid and PP. There are loads of posts here discussing the relative merits of each.
    If, however, you are a freelancer and are looking to pick up work then there may be a point to learning FCP7. Obviously it would depend on what the edit houses/potential employers in your area are using but the likely contenders will be Avid and FCP7. Possibly not so much Adobe yet but that will likely change fairly soon if CS6 lives up to its promise.
    But those still running FCP7 will likely be looking to change at some point soonish so I wouldn’t buy FCP7 to learn unless I knew I could make it pay in freelance gigs in the next year or so and needed it to pick up that work.
    I wouldn’t totally write off FCPX – its not for me either at this stage but I am keeping an eye on it, it would be foolish to dismiss it totally.
    It is a time of flux but over here many businesses are sticking with what they have and know just now, so there may be a year or 2 in the old FCP7 dog yet.
    I am UK based and in my particular work environment Avid dominates totally and those that have switched from FCP have switched to Avid. However some are waiting for all the dust to settle so there is still FCP7 work out there but it is diminishing.
    best wishes
    Neil
    http://www.patience.tv
  • Stephanie Joan
    May 13, 2012 at 5:48 pm
    Thanks for your input – looks like I’m going to take a look at Premiere. It’s incredibly frustrating that Apple killed the pro side of FCP. Is their home user base really that much more valuable than their professional user base?
    What are the relative merits, feature-wise, of Avid over Adobe?
    Stephanie
  • Neil Patience
    May 15, 2012 at 8:34 pm
    I think the merits of Avid over Adobe will depend on your workflow.
    Its hard to give a definitive list covering all pros and cons but from my perspective broadly:
    Avid is, in my opinion, the best cutting tool. Its totally solid and used by just about every high end broadcaster and film cuttng room in the world. If that kind of compatibility and a good collaborative workflow is important to you then Avid is the best choice.
    Avid now works with third party hardware and media composer on a Kona card for example seems very good indeed.
    However if you need tight integration with AE or other Adobe products or want to be able to open old FCP projects or work on something more familiar to FCP7 users, work in H264 more easily then PP is going to tick more boxes for you and be possibly the better option. Broadcast monitoring is, I understand, not quite yet up to par but its early days and I am sure will pretty quickly improve as third parties develop drivers.
    So each has merits and I think your work environment and workflow will be the bigeest factor in shaping your choice.
    best wishes
    Neil
