Activity › Forums › Avid Media Composer › New problem with extracting material
  • New problem with extracting material
    Posted by Steve Rogalinski on March 8, 2016 at 8:15 pm
    Hoping someone has an answer to this…
    I am having a consistent problem… Whenever I do a cut (extract) on the timeline my effect transition time is cut in half and only shows on the left side of the transition. It’s not because I don’t have enough handle room. It happens all of the time. It happens on audio tracks too. I believe this was a problem with Avid many generations ago that was addressed and corrected. Anyone have any guess as to why this is happening to me all of a sudden? Please message me if you have a solution.
    steve@sjrog.com
    Thanks much!
    Steven J Rogalinski
    Shane Ross replied 10 years, 6 months ago 3 Members · 2 Replies
  • Glenn Sakatch
    March 9, 2016 at 3:28 pm
    You are saying you have two shots next to each other with say a dissolve in between. If you extract the second shot, the dissolve gets buggered up? I’m not seeing this in 8.5 PC
    Glenn
  • Shane Ross
    March 9, 2016 at 4:29 pm
    Not seeing this with 8.5 Mac on 10.10.11 either. Nor on 8.5 10.9.5. I didn’t comment because I’ve never seen this behavior. Transition Preservation was introduced in Media Composer 3, I believe, and always worked. You know, you might need to trash the Avid preferences. Preference Manager from DigitalRebellion.com is free, and does that…even for Avid.
    Shane
    Little Frog Post
