Activity Forums Adobe Encore DVD new problem with encore hanging
  • new problem with encore hanging
    Posted by Woody Wright on May 25, 2010 at 7:03 pm
    Hi, Im new to this forum and new to adobe and video editing so any clarification, help is much appreciated.I have only been using this gear for 1 month, I have alot to learn.
    I recorded a band with sony ax2000,used cineform to convert to .avi, edited and sent to encore, built a simple menu, presto, DVD.
    Birthday party with canon HFS10,…easy.
    Yoga instruor, HFS10 same results.
    I used the sony to record a car show and the trouble started immediately in premiere pro,hanging…freezing.
    I finally got it finished, sent to encore, start build and the transcoding bar stops progressing in the same spot every time.No error message,just idle.Went back to B-day project and built a DVD no problem.
    I am sure this is operator error and I should have kept a record of downloads and updates.I am accumulating a list of possible fixes to apply that I have gathered from forums,just wanted to introduce myself and get a dialog going. Thanks for your time.
    Peter Higginbottom replied 15 years, 11 months ago 3 Members · 5 Replies
  • Raja Ashok
    May 26, 2010 at 2:50 pm
    Export the sequence to Mpeg-2 DVD using Adobe Media Encoder instead of send to encore. I suspect there is some problem with the video clip or the video is corrupt.
  • Woody Wright
    May 26, 2010 at 5:46 pm
    Thank you for responding.Yes, ME hangs on carshow project but processes B-day no problem.
    Is there any way to “uncorrupt” these files?
    I am chasing down an error code from my event log that seems to have originated from norton(.hsie2010.exe).
    That was about the time I was transferring the clips.
    First premiere hang was right after that event.
    Thanks for your response, its good to have help.
  • Raja Ashok
    May 27, 2010 at 10:33 am
    Are you able to export the AVCHD car show footages to .avi using cineform ? Are you using a trial build?
  • Woody Wright
    May 27, 2010 at 5:15 pm
    Hi, Yes I converted the avchd to avi in all 3 projects.I have a paid version of neoscene which I upgraded to version 5.0 just before the car show project.
    Its frustrating because at first everything worked so smoothly.
    I shot some new clips with both cameras last night and will see what happens.
    I will update soon. Thanks for your time RAJA.
  • Peter Higginbottom
    October 21, 2010 at 8:59 pm
    Searched this forum & what feels like the entire web.
    OS error code 370691, using Encore 1.5, on an Windows XP installation.
    Lucky Me its a friends computer & not mine.
    Hangs Encore at ” unable to validate disc” ejects disc & comes up with the error code.
    Any help would be gratefully recieved.
    Regards.
    Peter.
