New PC Specs and Premiere Pro
Hi.
I had a question regarding running Premiere Pro CS4 and a new PC I am looking at getting. I am on a limited budget and am more interested in a pre-built system and need it pretty fast.
My current system is choking in Premiere. Everything else runs fine but I can’t even play SD footage in Premiere.
Here is a link to the PC specs:
https://www.newegg.com/Product/Product.aspx?Item=N82E16883107989It is an HP and has most of the things I need but I was curious what others thought if this will get it done.
I will be editing mostly 720/24P footage from a Panasonic P2 since this is what the guy I get most of my freelance shoots on. Anything else would probably be SD. I also don’t need Blue Ray.
Thoughts, suggestions. Thanks.
