Activity Forums Adobe After Effects New PC – How do I configure for rendering?
  • New PC – How do I configure for rendering?
    Posted by James Malamatinas on January 27, 2010 at 9:20 pm
    I am at this very moment building a new PC but would like advice on how best to set-it up for After Effects and Premiere Pro. I would like to get it right from the beginning!
    I have:
    – Core i7 920 CPU
    – 6 GB DDR3 RAM (Triple Channel)
    – 2 x 1 TB HDD 7200 RPM
    Coming over from my old system I have
    – 2 x 250GB, 7200 RPM HDD
    I will be doing a new install with windows 7 64-bit.
    I read on Adobe forums that RAID isn’t worthwhile with this many drives, so what is best HDD configuration? Do I mess with Page File? Where do I put scratch discs and so forth?
    I’m a complete beginner!
    Scott Roberts replied 16 years, 7 months ago 3 Members · 2 Replies
  • Walter Soyka
    January 27, 2010 at 9:55 pm
    I don’t use Premiere Pro myself, but I can give you the After Effects perspective.
    [James Malamatinas] “I have:
    – Core i7 920 CPU
    – 2 x 1 TB HDD 7200 RPM”
    6 GB is not enough RAM to take full advantage of After Effect’s multiprocessing. You you want between 2 and 4 GB of RAM per core; with your quad-core and triple channel RAM, you should aim for 12 GB.
    Three hard drives would suit you well; one for your OS and apps, one for your footage, and one for your renders.
    [James Malamatinas] “I will be doing a new install with windows 7 64-bit. “
    Outstanding. You need the 64-bit edition to get access to all that RAM.
    Walter Soyka
  • Scott Roberts
    January 29, 2010 at 12:58 am
    If you’re second drive has space, use it to save cache files and all that so you’re not working off of one drive only and slowing things down.
    https://www.myr3d.com
