Activity Forums Adobe Premiere Pro New PC for Adobe Production Suite CS5.5
  • New PC for Adobe Production Suite CS5.5
    Posted by Aaron Cadieux on February 29, 2012 at 5:41 pm
    Hello,
    I am going to making a jump from Production Suite CS3 to CS5.5. In order to do that, I will be building a new dual Xeon Quad-Core 64 bit PC this spring. Some of this “Dream Machine” is based off of using B&H’s Adobe Production Suite optimized turnkey editing PCs. By building my own machine, I found that I can significantly improve on many aspects of the B&H machines and still stay well below their price. Here are the components I’ve picked out for my dream machine.
    3.06GHz Intel Xeon Quad-Core (Bloomfield) – 2 for $610
    nVIDIA Quadro 4000 with 2GB RAM – $726
    Intel 510 Series (Elm Crest) SSDSC2MH120A2K5 2.5″ 120GB SATA III MLC
    Internal Solid State Drive (SSD) – $239 (will be primary drive)
    EVGA Classified SR-2 270-WS-W555-A2 LGA 1366 Intel 5520 SATA 6Gb/s USB 3.0 HPTX Intel Motherboard – $550
    G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL – 6 for $240
    Blackmagic Decklink SDI – $295
    Microsoft Windows 7 Professional SP1 64-bit
    With this machine, I will be editing my projects on a Lacie 4Big Quadra external array connected via eSATA. I have the array set to RAID10.
    I guess my first question is, will this machine effectively run Adobe Production Suite CS5.5?
    My second question is in regards to RAM. I have the motherboard maxed out at 48GB of RAM. Obviously the machine itself will run like a clock with that much RAM, but how much of that RAM will the Adobe software bundle actually be able to utilize?
    I posted this in the Premiere forum, because that’s the software that I’ll be using the most on this machine.
    Thanks and I look forward to hearing your responses.
    -Aaron
    Larry Gordon replied 14 years, 4 months ago 11 Members · 24 Replies
  • 24 Replies
  • Angelo Lorenzo
    February 29, 2012 at 6:33 pm
    I would say so, I’m running an i7 2600 with 32gigs of Corsair 1600 Ram, SSD drive and so forth.
    The SSD in and of itself doesn’t help terribly with performance but if you use your computer as a DIT station, the multiple restarts or hiccups that we face on-set from dirty power or other issues, then at least you’re restarted quickly.
    Adobe products will utilize all the RAM, but Premiere is pretty good about things. After Effects is the program that will eat all your RAM and ask for more (I’m doing some RED color grading in 4K in AE with 32gigs and it performs respectably).
  • Aaron Cadieux
    February 29, 2012 at 6:44 pm
    I guess the other question would be am I better off with dual quad core Xeons, or a single i7 processor?
  • Tom Daigon
    February 29, 2012 at 7:45 pm
    It depends how much “heavy lifting” you are doing with your system. If you need to deal with formats like Red , Epic or high resolution 4444 files as well as the basic stuff (P2, AVCHD, XDCam, H.264, Prores, DNxHD, etc) My research with leading computer makers suggest the new xeons are the way to go. This is even more reinforced if you are doing long form and / or lots of motion graphics in the larger formats. Thats the direction I would like to go when I move on from my Mac Pro.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Joseph W. bourke
    February 29, 2012 at 10:06 pm
    Aaron –
    I wish you well with your build – I am 6 or months or so away from taking the DIY plunge and building my next graphics box, so I’ll look with interest on any follow ups you post. You may want to check out these guys:
    https://www.videoguys.com/Guide/E/Videoguys+DIY9+Sneak+Peek+Its+Time+for+Sandy+Bridge+E/0xe9b142f408a2b03ab88144a434e88de7.aspx
    They seem to know what they’re talking about, and, more importantly, they don’t seem to be trying to sell the hardware they are suggesting for the machines. I’ve learned a fair amount from their testing. Good luck!
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Walter Soyka
    February 29, 2012 at 10:19 pm
    [Tom Daigon] “My research with leading computer makers suggest the new xeons are the way to go. This is even more reinforced if you are doing long form and / or lots of motion graphics in the larger formats.”
    My work is mostly large format animation and motion graphics, and I’d agree with Tom.
    i7 is perfectly suitable for straight editorial, but effects, graphics, compositing and grading all benefit from more power.
    Walter Soyka
  • Tom Daigon
    February 29, 2012 at 10:22 pm
    Eric Bowen at ADK is a fount of knowledge. I will most likely get my machine from him. His ability to listen to your workflow and design a system to your needs is awesome.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Derek Andonian
    March 1, 2012 at 4:53 am
    You may want to hold off on your new Adobe purchase. CS6 is just around the corner
    ______________________________________________
    “THAT’S our fail-safe point. Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
  • Herb Sevush
    March 1, 2012 at 3:43 pm
    [Aaron Cadieux] “Blackmagic Decklink SDI – $295”
    Do you realize this card doesn’t handle HD?
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
  • Colin Lamb
    March 1, 2012 at 5:41 pm
    Aaron
    I have been building PC’s for myself and friends to use as edit stations for over 15 years.
    I usually ask them a series of questions about what they actually want to use it for (Premiere, AE, p/shop, animation etc, also source footage: – AVCHD, DSLR vid, P2, SD etc) and taylor a solution to fulfill their needs.
    For P5.5 your system will blow it out of the water but at a cost.
    If you can expand upon the source material you want to use now and in the future we can advise better.
    Col Lamb
    UK
    Own build custom PC ASUS x58 MOBO, 12Gb RAM, GTX 580 GPU, RAID 1 and RAID 0 in PC + Store HD, Boot and store in trayless caddies for easy swap, Synology network RAID storage
  • Aaron Cadieux
    March 1, 2012 at 6:43 pm
    Herb,
    I think you might be mistaken. This is taken directly off of the Blackmagic page.
    DeckLink SDI – $295
    DeckLink SDI is perfect when you need an SDI only solution but demand high quality 10 bit 4:2:2 based SDI capture and playback. DeckLink SDI plugs into Windows, Mac OS X and Linux computers and features HD/SD-SDI capture and playback combined with tri-sync/black burst reference input and RS-422 deck control. Media Express software is included so you get capture and playback for AVI, QuickTime and DPX on Mac, Windows and Linux. DeckLink SDI is a perfect choice when all your connections are SDI and you don’t need analog connections.
Page 1 of 3
