Activity Forums Apple Final Cut Pro Legacy New occurrance, old issue
  • New occurrance, old issue
    Posted by Eric St. john on May 1, 2011 at 10:50 pm
    I assure everyone I’ve spent the last three days Googling and reading. If this definitely redundantly recurring subject irks you, please forgive me. I’m posting here in hopes that someone besides the person writing the following listed blog can offer some insight into what I’ve found. This is the comment/question I originally wanted to post to the blog on how to solve the great Qmaster/Compressor snafu at: https://www.kashum.com/blog/1152611689
    It’s still having a server error so I can’t post there. Please bear with me, okay? Thanks!
    After attempting the manual start and some other entering in Terminal I discovered that my qmasterd file is missing.
    “5/1/11 2:30:16 PM Compressor[764] NSDocumentController Info.plist warning: The values of CFBundleTypeRole entries must be ‘Editor’, ‘Viewer’, ‘None’, or ‘Shell’.”
    I ran Console like someone else had and found this some thirty-two times consecutively:
    “5/1/11 2:30:16 PM Compressor [764] NSDocumentController Info.plist warning: The values of CFBundleTypeRole entries must be ‘Editor’, ‘Viewer’, ‘None’, or ‘Shell’. ”
    And then lastly:
    “Warning once: This application, or a library it uses, is using NSQuicDrawView, which has been deprecated. Apps should cease use of QuickDraw and move to Quartz.”
    The StartupParameters Plist showed this:
    <?xml version=”1.0″ encoding=”UTF-8″?>
    <!DOCTYPE plist PUBLIC “-//Apple Computer//DTD PLIST 1.0//EN” “https://www.apple.com/DTDs/PropertyList-1.0.dtd”>
    Description
    Qmaster services
    Messages
    start
    Starting Apple Qmaster services
    stop
    Stopping Apple Qmaster services
    OrderPreference
    Late
    Provides
    Qmaster services
    Requires
    Disks
    Resolver
    Network
    And finally, the qmaster terminal start log showed this:
    “Last login: Wed Apr 27 22:15:57 on ttys000
    mac2s-power-mac-g5-48:~ mac$ cd /Library/StartupItems/Qmaster
    mac2s-power-mac-g5-48:Qmaster mac$ sudo /Library/StartupItems/Qmaster/Qmaster start
    Password:
    Starting Qmaster services
    mac2s-power-mac-g5-48:Qmaster mac$ /Library/StartupItems/Qmaster/Qmaster: line 12: /usr/sbin/qmasterd: No such file or directory
    Last login: Thu Apr 28 07:53:03 on console
    mac2s-power-mac-g5-48:~ mac$ cd /usr/sbin
    mac2s-power-mac-g5-48:sbin mac$ qmasterprefs -list
    -bash: qmasterprefs: command not found
    mac2s-power-mac-g5-48:sbin mac$ cd /usr/sbin
    mac2s-power-mac-g5-48:sbin mac$ “qmasterprefs -list”
    -bash: qmasterprefs -list: command not found
    Last login: Thu Apr 28 13:16:43 on ttys000
    sanjuan:~ sanjuan$ ls -l /Library/Application\ Support/Apple\ Qmaster/
    total 56
    -rw-r–r– 1 root admin 234 Feb 3 2008 QmasterApplications.plist
    -rw-rw-rw- 1 root admin 267 Feb 3 2008 qmasterconfig
    -rw-rw-r– 1 root admin 267 Jul 5 2005 qmasterconfig.default
    -rw-rw-rw- 1 root admin 4722 Apr 27 15:53 qmasterservices.plist
    -rw-rw-r– 1 root admin 2057 Jul 5 2005 qmasterservices.plist.default
    -rw-rw-r– 1 root admin 1318 Jun 27 2005 transcoderx.plist.default
    sanjuan:~ sanjuan$”
    I’ve downloaded Pacifist and have the “how to reinstall this via the Compressor Repair site” page open.
    I’ve taken a deep breath and am about to pull out the two culprits and re-install them. God, I hope this works! (Thanks Richard, for your very helpful advice!)
    What do you all make of the various logs?
    Anybody?
    Cheers,
    Eric
    Eric St. john replied 15 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
