Activity Forums Blackmagic Design New Motherboard experience for Multibridge Pro
  • New Motherboard experience for Multibridge Pro
    Posted by Michal Lukaszyk on December 3, 2007 at 12:49 pm
    Hello
    I am looking good motherboard for Multibridge PRO(hd-sd) with core 2 quad processor. Have you got any experience.
    I tried to install multibridge pro on asus p5w64 but when i put the card on third slot motherboard hung up and not started.
    Please advise me what kind of motherboard i must to buy.
    Michal Lukaszyk
    Yasser Amin replied 18 years, 9 months ago 3 Members · 8 Replies
  • 8 Replies
  • Manololp
    December 8, 2007 at 9:09 am
    Hello.
    The decklink card should be put in an x1-x4 PCIe slot.
    Have you tried to change the bios settings for that slot?
  • Michal Lukaszyk
    December 9, 2007 at 6:04 am
    Hi
    Thank you for your response.
    P5W64 have 4 pci-e slots. nr1 blue and nr 2 are reserved by graphics card (I have quadro fx 4500)
    When I put Multibridge PRO card in slot 3, mainboard not started( on power on Balck Screen and Silence)
    When i put Multibridge PRO card in slot 4 everything is ok system loading but Multibridge PRO card hasn’t been found.(I’am trying to find new hardware but still nothing happens)
    When I try to connect Multibridge PRO via USB, system found 1 new hardware and install it but there is still nothing heppens. I can’t run Multibridge PRO
    In mainboard manual I see the slots runs at (1)x8 (2)x8 (3)x4 (4)x8 mode or at (1)x16 (2)x0 (3)x4 (4)x0 mode.
    In bios setting i found only 5 things about pci-e:
    PEG buffer Lenght(use AUTO) otions:(auto,long,short)
    Link Latlency (use Auto) options:(auto,slow,normal)
    PEG Root Control (use Auto) options:(auto,disable,enable)
    PEG Link Mode (use Auto) options:(auto,slow,normal,fast,faster)
    Slot Power (use Auto) options:(auto,light,normal,fast,faster)
    that’s all.
    Please help if you have any suggestions.
    MIKE
  • Manololp
    December 10, 2007 at 9:42 pm
    Hello.
    This card is a card game, it does not seem the most appropriate for Multibrige.
    The only slot for multibrige that you can use is the number 3, in single card mode (slot 1: vga (x16 mode), slot 3: multibrige (x4 mode)).
    If this no works, then other bios settings are: “boot graphic adapter priority” and “High priority port select”. Try with this settings.
    Luck
  • Manololp
    December 10, 2007 at 9:46 pm
    This is the official recomendation page on Blackmagic site:
    https://www.blackmagic-design.com/support/detail.asp?techID=152#DualCore_PCIeHD
  • Michal Lukaszyk
    December 13, 2007 at 8:25 am
    Hello
    Yesterday I bought new version multibridge pro 2 and update bios in my ASUS P5W64 WS Professional and everything working perfect hd and sd.
    Thanks for help
  • Yasser Amin
    December 13, 2007 at 1:29 pm
    Hello Michal
    I am very interest in ASUS P5W64 WS Professional and have a questions about it
    1- did you test all PCI-e slot with Multibridge PRO especially slot 1 x4 after bios update
    2- there is many reports about problem between X38 and PCI-e raid card, did the bios update solve this problem, and what is the raid configuration that you use with Video
    thanks
  • Michal Lukaszyk
    December 14, 2007 at 4:47 am
    Hi Yasser
    I wrote:
    “P5W64 have 4 pci-e slots. nr1 blue and nr 2 are reserved by graphics card (I have quadro fx 4500)
    When i put Multibridge PRO card in slot 4 everything is ok system loading but Multibridge PRO card hasn’t been found.(I’am trying to find new hardware but still nothing happens)”
    Then I upgrade my bios from version number 0701 to 0903 and connect new Multibridge PRO v2 to slot nr 3(because in that configurations it has PCI-e x4(go to asus website an read motherboard manual)) and everything working.
    I think the problem was in old Multibridge Pro slot connecting card because in that version of MB the card looking different, but remember it’s only my opinion.
    I don’t know nothing about chipset X38 this motherboard has Northbridge Intel 975X Southbridge Intel ICH7R and PCI-E IDT89HA0324 and 8 x serial ATA I/II(4 on ICH7R and 3+1 on Marvell 88SE6145) and RAID bulid on MARVELL working.:)
  • Yasser Amin
    December 19, 2007 at 2:08 am
    Hi Michal
    thank you for replay, There has been a misunderstanding, I read your post and don’t know how I read P5W64 as P5E64 which I mean in my replay
    thanks
