Activity › Forums › Adobe Premiere Pro › New monitor/color correcting
    May 28, 2024 at 2:25 pm
    Hey Mary,
    What LED monitor are you using?
    And, what resolution are you working at?
    Took far too long to find the specs, but looks good as they have rec 2020 included:
    𝗖𝗨𝗦𝗧𝗢𝗠 𝗖𝗔𝗟𝗜𝗕𝗥𝗔𝗧𝗜𝗢𝗡
    𝗙𝗘𝗔𝗧𝗨𝗥𝗘𝗦: For users wanting more advanced calibration features,
    X2 Elite includes Video & Cinema Targets (Rec. 709, Rec. 2020);
    Advanced Display Mapping & Analysis; Unlimited Calibration Settings;
    Soft Proofing; and Studio Match for multiple monitor calibration.
    And, it is on offer right now (UK).
    But if you are aiming for HEVC, they suggest the X2 Ultra to be a better choice:
    Dаtасоlоr Ѕруdеr Х Ultrа 2 Кеу Fеаturеѕ:
    Аdvаnсеd соlоurіmеtеr fоr саlіbrаtіоn оf dіѕрlау соlоur ассurасу
    Мах lumіnаnсе mеаѕurеmеnt оf 2000 nіtѕ, реrfесt fоr НDR dіѕрlауѕ
    Ѕtudіо Маtсh аllоwѕ fоr сrоѕѕ-dіѕрlау соnѕіѕtеnсу wіth thе саlіbrаtіоn оf 3+ mоnіtоrѕ
    Rаngе оf fеаturеѕ thаt аnуоnе frоm bеgіnnеrѕ tо ехреrtѕ wіll аррrесіаtе
    Wоrkѕ wіth dеѕktор mоnіtоrѕ, аll-іn-оnеѕ, lарtорѕ аnd рrојесtоrѕ
    Dіѕрlау аnаlуѕіѕ аnd mарріng fоr а соmрlеtе rundоwn оf dаtа
    Вuіlt fоr uѕе іn brіght lіght ѕеttіngѕ ѕuсh аѕ оutdооr dіѕрlауѕ
    Ѕоft Рrооfіng fеаturе fоr іn-dіѕрlау соlоur рrоfіlе ѕіmulаtіоnѕ
    UЅВ-С соnnесtіvіtу wіth UЅВ-А аdарtеr fоr оldеr ѕуѕtеmѕ
    Fіvе bасklіght орtіоnѕ fоr dіffеrеnt lіghtіng ѕсеnаrіоѕ
    Іdеаl fоr рhоtоgrарhу аnd vіdео соlоur grаdіng
    Ѕuрроrtѕ Rес.709 оr 2020 соlоur ѕрасе tаrgеtѕ
    ОЅ соmраtіbіlіtу wіth Wіndоwѕ аnd МасОЅ
    Hope that this helps?
    PS: After writing this post I did further research. If you in the future are looking at 10,000 nits and/or want to calibrate and OLED screen. For little more, you may want to consider the Calibrite Display Plus HR:
    https://calibrite.com/product/display-plus-hl/
  • Mary Gerber
    May 28, 2024 at 3:09 pm
    Thank you so much for your time looking at this with me. I’ve attached a screen shot of the monitor specs.
    May 28, 2024 at 3:34 pm
    Hey Mary,
    Thank you.
    You’ve got a big monitor, at a competitive price.
    Have you checked the calibration sheet for the monitor?
    “【ΔE <2 Color Calibration & TUV
    Authentication & Blue Light Reduction】Each INNOCN monitor coming
    with color calibration report, the ΔE <2, deeply restore the true
    nature colors. Low blue light technoilogy ensure the comfot when long
    time watching or playing, INNOCN monitors are TÜV Rheinland certified.”
    Although at least one review complains about the red colour, it might already be calibrated for you.
    Have not checked how PPro reacts, but have recently by remote been involved in a job where the monitor did not appear to give the same out-put as the final file. This was on Davinci – the conclusion so far (might change), that the output of the Computer was not compatible with a HD signal.
    There are a few other reasons for why that could happen. But we are currently investigating inserting a BlackMagic Design UltraStudio Monitor 3G mini between the computer and the monitor. And, then use Callibration device to line up the screen.
    Should add that the Ultrastudio Monitor 3G has both HDMI and SD/HD-SDI. This will allow you to confidence check on a Broadcast monitor, if you still have that access?
    But don’t think that it will do both HDMI and SDI out simultaniously.
    Apart from the 500 nits being a bit “low”, there is nothing else that stands out on your choice of monitor. If anything, it is a very recent release.
  • Mary Gerber
    May 28, 2024 at 4:37 pm
    Yes, it is helpful. Thank you
