Activity › Forums › Adobe Premiere Pro › New monitor. Clips look fine, but have yellow tint in PPro
  • New monitor. Clips look fine, but have yellow tint in PPro
    Posted by Duke Sweden on January 14, 2017 at 9:04 pm
    I finally “upgraded” from a 720p HDTV monitor to 1080p. Huge difference. I was shocked how horrible my old videos looked. I was color correcting and grading blind, almost.
    Anyway, when I view white balanced, properly exposed video straight from my camera in VLC viewer, it looks fine, but when I open it in Premiere Pro there’s a yellowish tint to it. I can correct it, but then I don’t know if I’m making it too red. I’m not sure which color profile to rely on.
    Here’s a video I just shot for test purposes this morning. You only have to watch the first few seconds. Do the colors look ok? I’m going for a slightly cool look with this grade. Other than that, is it possible for the color profile in Premiere to be off, with a way to adjust it?
    https://www.youtube.com/watch?v=BKn_dmg66Os&feature=youtu.be
    Duke Sweden replied 9 years, 8 months ago 2 Members · 5 Replies
  • Tero Ahlfors
    January 14, 2017 at 9:15 pm
    You need to try and calibrate your monitor to a somewhat decent level. You can use the built in calibration in Windows that can be found in the display control panel settings.
  • Duke Sweden
    January 14, 2017 at 9:23 pm
    I did calibrate, Tero. Everything looks great, except that clips imported into Premiere Pro have a yellowish tint even though they look fine OOC on VLC. Ignore the sample video, once again I butchered the grading.
  • Duke Sweden
    January 14, 2017 at 9:26 pm
    Here is the ungraded video right out of the camera. I manually white balanced. Never had a problem with that before. Does this look correctly wb’d or does it have a yellow tint?
    https://www.youtube.com/watch?v=Bw6wGgP6UaM
  • Tero Ahlfors
    January 14, 2017 at 9:38 pm
    I haven’t made any serious calibration to my home displays but my eyeball calibrated monitors don’t show a strong tint in the clips. The first one is cooler and the second one is warmer but I wouldn’t say that it’s to an effect.
    Does your monitor have any white balance/color temp settings? Make a white matte in Premiere (new item – color matte) and see how it looks. Then try to set the monitor so the white is close to as pure white as you can.
  • Duke Sweden
    January 14, 2017 at 10:41 pm
    Yes, one is graded to the cool side and the other is straight out of the camera. My tv does have a white balance. I made all the adjustments. The only one I disagreed with is brightness. Correct brightness was way too bright so I lowered it a bit.
    I just shot some more footage although it’s starting to get dark here. I raised the tint to +1 on the GH4 and adjusted wb by the kelvin scale, much better result but since no one ever suggests raising the tint I have to believe it’s the tv that’s off.
