Activity Forums Apple OS X New Monitor
  • New Monitor
    Posted by Glenn Pniewski on August 27, 2009 at 9:10 pm
    Hi there,
    Hopefully I’m in the right place. So I’ve got a PowerMac G4 867Mhz, running OSX 10.4.11. An old machine, but it’s been good to me.
    My flat screen monitor went out on me and I replaced it. Went to Best Buy, got myself a little Dell 19-inch “widescreen” monitor. That’s all you can get these days, I guess.
    Well, everything’s hooked up fine, colors are brilliant, but I can’t undo the s t r e t c h. I’ve tried all the displays settings in Preferences. Clear picture, just too elongated.
    I work with Final Cut Pro, this setting is “livable”, but is there any way to fix it?
    Thanks –
    Ray Chung replied 17 years ago 2 Members · 1 Reply
  • Ray Chung
    August 30, 2009 at 12:37 am
    If this is the monitor you’re talking about….
    https://www.bestbuy.com/site/olspage.jsp?skuId=9366063&st=dell+monitor&lp=2&type=product&cp=1&id=1218092173453
    …it seems to be a very strange animal indeed. Its aspect ratio is listed as 16:9 (and from the pictures, it looks to be that), but its native resolution is listed as 1440×900….which is 16:10. Meaning that if it is displaying things at 16×9, then it is squeezing the picture vertically, giving you that stretched look. This is a very odd configuration, and I can’t see why they would make a model like that. If this is indeed the case, I would return the monitor and opt for the slightly more expensive Dell 19″ (the silver one), which has the same 1440×900 native res, but the right kind of 16:10 screen ratio. A really odd choice for a design on that black one.
    The one that’s listed on the Dell site…..
    https://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&s=bsd&cs=04&sku=320-7459
    …says that it’s 16:10, and on that site it looks like it in the pictures, whereas the one on the Best Buy site looks narrower top-to-bottom and says that it’s 16:9. Really……strange.
