Activity Forums Apple Final Cut Pro Legacy new memory not read by FCP
  • new memory not read by FCP
    Posted by Maurik De ridder on September 17, 2007 at 5:26 pm
    Hi there…
    I just recently installed 4 GB of extra RAM besides the 2,5 GB I already had…
    But now i checked FCP in the System Settings under Memory and Cache and i see
    it still only has 2,5 Ram under Memory usage Application…
    Does anybody know why the new 4 GB arent used by FCP
    In the system profiler it does read 6,5 GB Ram
    thanx
    maurik
    Rafael Amador replied 19 years ago 4 Members · 3 Replies
  • Walter Biscardi
    September 17, 2007 at 5:28 pm
    I believe FCP still only uses 2GB RAM. I haven’t gone into the FCP Help Menu to check, but I don’t think that changed with FCP 6. Might change with Leopard.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Neil Ryan
    September 18, 2007 at 3:44 am
    The placement and order of the memory chips is also important; I can’t remember where the detail is though …
  • Rafael Amador
    September 18, 2007 at 4:29 am
    What has been always recommended is to install the RAM in pairs Extract the original chips and install the news to see if they work.
    it seems tha FC can not yet use more than 2Gbs of memory although some application (AE CS3) it suposed can do it.
    cheers,
    rafael
