Activity › Forums › Apple Final Cut Pro Legacy › New MacPro?
New MacPro?
Posted by Adam Taylor on January 11, 2012 at 4:12 pmaside from the usual “wait to see whats just around the corner” advice regarding new Macs, how foolish would it be to consider getting a new 12 core mac with the intention of running FCP7 ?
I am not intending to use FCPX in any way, so that is not a consideration.
thanks
AdamAdam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UKJim Murphy replied 13 years, 1 month ago 7 Members · 11 Replies -
David Roth weiss
January 11, 2012 at 4:27 pmI’d advise that you buy a machine with specs that will handle both Avid and Premiere as well, because there will come a time in the next year or so when your clients have all headed for the hills and abandoned FCP completely. So, get a good Nvidia card that’s qualified for the two other A’s, as it will certainly work for legacy FCP in the interim.
However, the other side of the argument is to wait to see if a T-Bolt enabled MacPro is coming out soon.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Jean-christophe Boulay
January 11, 2012 at 7:03 pmHi Adam,
As far as “it’s just around the corner” goes, that corner may be a few months away. With Intel presently rolling out its LGA2011-based upmarket CPUs, the new Xeon E5’s are reported to be two to three months from launch still. It makes sense for Apple to wait for the new platform, considering the quite major architecture upgrade. If Apple design the MacPro to the full potential of the platform, it could be quite a big step up from the current models but with the quad-channel memory setup, steady high-density memory prices and Apple’s insistence on cramming two super-expensive CPUs inside every box, the prices will probably be going up as well. Early benchmarks of the platform suggest the most worthwhile gains in heavily threaded workstation applications, which is not really FCP7’s case. Not that much sense waiting around, then. I personally don’t think Thunderbolt is any reason to wait as it’s useless without devices to plug into, which consist of a few RAID enclosures right now and most editors are covered on that front already.
If you go for the current machine, you’ll get a super capable system now for what will probably end up being a wad of cash less than an eventual revision. David’s advice on going for an Adobe-approved nVidia GPU to unlock CUDA potential is excellent.
IHTH
JC Boulay
Technical Director
Audio Z
Montreal, Canada
http://www.audioz.com -
Andrew Kimery
January 12, 2012 at 1:29 amI’m of a different theory about Thunderbolt. I’m waiting for new ThB enabled towers since it’s not something that can be added to an existing machine via card. If I needed a new tower *now* I would certainly buy one, but since I’m not under duress I’m going to wait.
I have a MBP with ThB and I like the idea of being able to use the same external devices regardless of I/O across my machines. Matrox and Blackmagic Design have ThB video I/O solutions. LaCie and Belkin are showing off ThB docks at CES (LaCie as showed off a ThB drive). Egato, Seagate, and OCZ announced bus-powered ThB pocket SSD drives. MSI announced an external PCI case that connects via ThB. Sonnect Tech has an ExpressCard/34 card reader the connects via ThB (great for the new 15″ MBPs that don’t have ExpressCard slot).
The list of devices is growing and I only expect it to get longer now that Apple’s window of exclusivity is gone. ThB is an Intel tech and I bet you they’ll be pushing it hard (PCs w/ThB are supposed to start becoming available this spring).
-Andrew
2.9 GHz 8-core (4,1), FCP 7.0.3, 10.6.6
Blackmagic Multibridge Eclipse (7.9.5) -
Adam Taylor
January 12, 2012 at 9:12 amthanks guys – echos many of my own thoughts.
Certainly agree about the Nvidia card… I bought my current ATI card to use mainly with Color,3 months before adobe announced the mercury engine!
Thunderbolt holds no interest for me. I don’t have any TB devices, and dont foresee getting any in the near future. All my storage is on fibre channel raids, so i just need to add to those when i need more.
Davids comments about clients leaving FCP is irrelevant to me. All the commercials i make are for our own products and the boss is only interested in results – he has not one clue about how i achieve those results.
thanks for your thoughts.
adamAdam Taylor
Oldham, UKhttp://www.sculptedbliss.co.uk
My YouTube Animations Page -
Ben Holmes
January 12, 2012 at 12:20 pmPut it this way – prices on those current 12-cores will plummet if new ones are announced, so you’ll lose if you don’t wait. Even if you plan to keep using FCP7, you’ll see gains on newer machines – it’s amazing how well the Quad-core i7 iMacs run with both this and AE.
Also – you might want to consider that new machines = new OS – you’ll need to transition to Lion if you haven’t already – but buying an EOL 12-core would avoid it.
Opinion piece follows:
CUDA on CS5.5 is a unicorn feature – always sought after, but rarely delivering real benefit in most existing FCP workflows (it accelerates only some effects and transitions and some playback), and PPro is a poor-man’s FCP still in most cases. That’s my opinion anyway. So don’t worry about cards yet. Maybe CS6 will see some real-world advantages. Me? I’m staying with FCP7 until I either have a compelling reason to change, or FCPX steps up – it’s rather fun! That’s if AVID doesn’t pull me back to 1999 before then…
Ben
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producerhttps://www.blackmagic-design.com/community/communitydetails/?UserStoryId=8757
Adam Taylor
January 12, 2012 at 1:21 pmIts mainly the Lion issue that is causing me concerns. I haven’t jumped to it yet, because of concerns that FCP7 may not be as happy with it.
As for Cudai’m on the fence – i tried using cs5.5 PPro a couple of times and had ridiculously slow load times and a whole host of other issues. I gave up in the end.
Avid is certainly looking more appealing than it did when i last used it 8 or 9 years ago – but i still feel its not quite as flexible when it comes to layering graphics etc. On the plus side, its supposed to be far more integrated with ProTools now. If i could edit and mix in the same app – that would be a big step for me.
All dreams for now – i still need to work up a cost analysis and confuse the boss some more!
Wonder if i can get him to stump up for Smoke?adam
Adam Taylor
Ben Holmes
January 12, 2012 at 2:56 pmI don’t use Lion on my main systems, but have it on a laptop and there are no issues with FCP7 – and I’ve seen none others reported, so I wouldn’t worry to be honest. I’ve noticed new drivers for some cards (I have Kona, BM AND Matrox video devices) are Lion specific, so to be honest, it may be safer to move over sooner or later. It’s definitely a good time to up your RAM!
Ben
Edit Out Ltd
Jim Murphy
August 20, 2013 at 12:09 pmAny recommendations on upgrading the GPU? I have a MacPro 2010 tower with the stock card. What card would be a logical upgrade and what type of increased performance should I expect using FCP7?
David Roth weiss
August 20, 2013 at 5:35 pmThe GTX 680 Mac Edition is the top GPU available for Mac Pros, and they are only about $500. I just bought one myself in fact.
The benefits of the GTX 680 in FCP legacy will be minimal, as that software was never written to benefit from GPU acceleration. With Premiere, the benefits are HUGE.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.comSales | Integration | Support
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
