Activity Forums Adobe After Effects New M3 Macbookpro for After Affects
  • New M3 Macbookpro for After Affects
    Posted by Stasia Lenhart on February 12, 2024 at 1:33 pm
    Has anyone tried working in After Affects on the new MacbookPro 2024 with the Max3 chip? If you have does it work well, and do you have any recommendations for specs if buying one.
    Eric Santiago replied 2 years, 7 months ago 3 Members · 3 Replies
  • Hector Vera
    February 12, 2024 at 2:33 pm
    First of all, you misspelled “Affects” which is supposed to be “Effects” in After Effects. And I while I do not own a Macbook, I have no doubt that After Effects should run just fine on the newest Macbook with that chip. Its supposed to be optimized to run all the latest software and millions of people indeed uses Adobe products within a Macbook especially! Are you planning to get one soon?
    As for the specs, here is the link explaining the minimum requirements to run Adobe After Effects 2024: https://helpx.adobe.com/after-effects/system-requirements.html
    Hope it helps! And best of luck!
  • Stasia Lenhart
    February 12, 2024 at 3:16 pm
    Yes After Effects. Posting pre-coffee post Superbowl.
  • Eric Santiago
    February 12, 2024 at 4:41 pm
    I’ve heard good things as far as the latest version.
