Activity › Forums › Apple Motion › New Lens Flare Tutorial
  • Andy Dolphin
    November 7, 2015 at 3:28 pm
    Part 2
    Adding the Lens Flare Generator and a replicator. The whole flare assembly is animated using a single controller.
    Some steps could be simplified by duplicating layers or copying links then simply changing parameters.
    I used the flare built in the tutorial to create the final transition by exporting a short Pro-Res file then importing into the composite project (also done in Motion 5) and adding a blend mode.
    There’s plenty more that can be done to this to make it more interactive and adaptable.
    https://www.youtube.com/watch?v=V4shNQT09aE
