Activity Forums AJA Video Systems *NEW* KONA LH 1.1.5 driver software available now
  • *NEW* KONA LH 1.1.5 driver software available now
    Posted by Aja Sales department on October 11, 2005 at 6:53 pm
    Hello-
    Please note that new KONA LH driver software, version 1.1.5, is available for immediate download at the KONA support section of our website:
    https://www.aja.com/support_kona.html
    This new KONA LH 1.1.5 driver software is recommended for all KONA LH owners. As with our previous versions, it is compatible with Apple’s Final Cut Pro 5 or Final Cut Pro 4.5, and OSX 10.4 “Tiger” (needed for FCP5), or OSX 10.3.8 and 10.3.9 “Panther”.
    In This Release:
    – New Feature: Added a control to the KONA Control Panel application to set the Analog Audio Full Scale level to +18 or +24 dBfs. This control works on both the analog input and output signal. If your selected audio input is analog then changing this control affects the digital level when the KONA is in monitor (EE) mode. There will be no change to the analog level in monitor mode because the adjustment to the analog output cancels the adjustment to the input. During capture or playback (operational mode), the analog level will be adjusted accordingly and the digital level will not be affected.
    – Fixed a problem with 1080i25 analog input.
    – Fixed a timing problem when HD input was downconverted to SD.
    – Fixed a problem where sometimes the downconverter was not properly enabled when there was no analog signal present.
    Full information on new features in this new KONA LH 1.1.5 software can be found in the included Read-Me.
    As always, please contact us if you have any additional questions, to sales@aja.com, (530) 274-2048, or support@aja.com, (530) 271-3190.
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
    Ben Cheng replied 20 years, 11 months ago 3 Members · 4 Replies
  • Gary Adcock
    October 11, 2005 at 7:26 pm
    [AJA Sales Department] “- New Feature: Added a control to the KONA Control Panel application to set the Analog Audio Full Scale level to +18 or +24 dBfs. This control works on both the analog input and output signal. If your selected audio input is analog then changing this control affects the digital level when the KONA is in monitor (EE) mode. \
    – Fixed a problem with 1080i25 analog input. “
    Thanks for understanding and appreciating the needs of the PAL market.
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Ben Cheng
    October 12, 2005 at 5:58 am
    Hi
    May I know for Mac OS X 10.4.2 + Kona LH 1.1.5, whats the certified + support version of QT ?
    Cheers
    Ben
  • Aja Sales department
    October 13, 2005 at 5:52 pm
    Hi Ben-
    Sorry, missed this post. Currently, we recommend QT 7.0.2, are we are now evaluating the release version of QT 7.0.3.
    Thank you,
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
  • Ben Cheng
    October 14, 2005 at 8:34 am
    Hi
    It will be great if AJA can update the “AJA Config Guide” regularly to reflect the changes of the drivers + Mac OS X + QuickTime supported
    Cheers
    Ben
