Activity › Forums › Apple Final Cut Pro Legacy › new IoHD lookalike … sort of
Posted by Andy Mees on May 20, 2008 at 3:06 pmDevin Clarke replied 17 years, 5 months ago 13 Members · 21 Replies -
Walter Biscardi
May 20, 2008 at 3:17 pmYeah, and I’m sure it works just as well as the other one. I can’t tell you how many people told me they purchased the original one and replaced it within months with a “real video I/O device, the Io HD.”
They still have all these multiple connections for Component, SDI, etc… The AJA boxes can autoswitch so you don’t need so many connectors.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Will Salley
May 20, 2008 at 5:57 pmIt’s actually an upgrade to the MOTU V3 – which was introduced before the ioHD. It’s not as popular as the AJA unit because MOTU is primarily an audio device designer. It, like the ioHD, is limited in function because of the data bottleneck imposed by the Firewire connection.
Walter Biscardi
May 20, 2008 at 6:29 pm[Will Salley] “It, like the ioHD, is limited in function because of the data bottleneck imposed by the Firewire connection.”
The only function the Io HD is limited to is Uncompressed HD. Other than that, it has all the capabilities of the Kona 3.
If external HD hardware is what you need, then the Io HD is really what you want.
Read my Blog!
Steve Eisen
May 20, 2008 at 6:37 pmAnd all this talk before the Matrox MXO 2 is released.
Like all pieces of equipment, it is how you use it in your workflow.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Walter Biscardi
May 20, 2008 at 6:40 pm[Steve Eisen] “And all this talk before the Matrox MXO 2 is released.
Like all pieces of equipment, it is how you use it in your workflow.”
I would definitely take the MXO 2 over anything from MOTU. It’s not the same as the Io HD, I would still take the Io HD for all the versatility, but the MXO 2 is a vast improvement over the original MXO. At least we hope it will be when its released.
Read my Blog!
Ed Dooley
May 20, 2008 at 6:50 pmOne big, big, vast improvement is that it’s no longer just an O box, now it’s an I/O box. I hope they don’t drag their feet for 7-8 months or more to update compatiblity/usability whenever a new graphics card comes out though, like they did when Macbook Pros changed cards, rendering the MXO totally useless with them. It didn’t stop them from ads showing a MBP hooked up to the MXO either. (Insert grumble here)
Ed[walter biscardi] “I would definitely take the MXO 2 over anything from MOTU. It’s not the same as the Io HD, I would still take the Io HD for all the versatility, but the MXO 2 is a vast improvement over the original MXO. At least we hope it will be when its released.”
Tony Manolikakis
May 20, 2008 at 7:06 pmThe MXO2 does not have the Scan Converting mode or the artifact removal for DVI viewing and it does not connect through DVI. This should eliminate a lot of complexities with changing graphics card and dependency on graphic card software fixes.
Tony Manolikakis
Rev13 Films -
Ed Dooley
May 20, 2008 at 7:12 pmThat’s good. I nearly bought one, but held off because of the graphic card fiasco.
Ed -
Gary Adcock
May 20, 2008 at 7:14 pm[walter biscardi] “The only function the Io HD is limited to is Uncompressed HD.”
I think you meant that the IoHD is limited to ProRes Compressed HD Capture. It can capture uncompressed SD content without issue.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Gary Adcock
May 20, 2008 at 7:17 pm[Ed Dooley] “One big, big, vast improvement is that it’s no longer just an O box, now it’s an I/O box.”
True, however it will take a vast amount of CPU power to be able to make the MXO2 capture to ProRes- where the IoHD shines is that the video compression is controlled in the device rather than allowing the CPU to handle the load.
Hardware processing means real time- no waiting, dumping that load into a laptop for processing is asking for issues.
gary adcock
Studio37
