Activity Forums AJA Video Systems NEW Io software available for download, v2.0 driver, and v1.0 Io Control Panel
  • NEW Io software available for download, v2.0 driver, and v1.0 Io Control Panel
    Posted by Aja Sales department on June 28, 2005 at 12:06 am
    Hello-
    Please note that final versions of both the Io family driver software version 2.0, and the final version 1.0 of the Io Control Panel, are availbale for immediate download at the Io support section of our website:
    https://www.aja.com/support_Io.html
    Changed In This Release:
    – New Firmware supports a new Io Control Panel application (included).
    In this release, you can also now update firmware simply by running the new Control Panel (supplied), which then tells you if you need the firmware update (it will supply the correct version for the model of Io attached).
    – Enables ProcAmp controls, for analog and digital signals.
    – Output Timing Controls enabled.
    – Analog Audio Levels controls enabled.
    Io Driver v2.0 for Io/IoLA/IoLD is the final version of the v2.0b beta that was previously posted. Changed In This Release:
    – Includes 23.98 Easy Set-ups.
    Full information on new features in the 2.0 software can be found in the included Read-Me.
    As always, please contact us if you have any additional questions, to sales@aja.com, (530) 274-2048, or support@aja.com, (530) 271-3190.
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
    Aja Sales department replied 21 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Mathieu
    June 28, 2005 at 3:40 pm
    Is this version of the driver supposed to enable the TBC controls in the FCP capture window too?
  • Lee Berger
    June 28, 2005 at 6:46 pm
    I installed the Io software, firmware and control panel last night. All was well until I tried to capture from my DSR-1500A and UVW-1800 via RS422; no VTR communication. Also a preset I made yesterday disappeared. I reverted to the previous firmware and device control returned. I’m running OS 10.3.9 and FCP 4.5. I may try again after I install Tiger and FCP 5.
    Lee Berger
    Lee Berger Media Productions, Inc.
    http://www.leebergermedia.com
  • Jeff Handy
    June 28, 2005 at 7:26 pm
    So is this upgrade only for Tiger users? Only for FCP5 users? Who is it for exactly? I’m sure there is a readme file that explains everything. But you know how many people actually read those! 😉
  • Brian Conner
    June 29, 2005 at 3:01 pm
    No, you have to tweak in Control Panel, then those settings will be in place when you bop back into FCP.
    Brian Conner
  • Mathieu
    June 29, 2005 at 4:46 pm
    I’ve installed the Control Panel 1.0 and Drivers 2.0 on 10.3.9 and FCP HD and it work fine with uvw-1800 and DVW-500 with 422.
    Too bad we can’t access control of procamp in FCP Capture window.
  • Bob Woodhead
    June 29, 2005 at 9:16 pm
    [Mathieu] “Too bad we can’t access control of procamp in FCP Capture window.”
    Amen, brother! Give us that, and a way to save the proc settings. And as long as I’m wishin’ – how about being able to batch capture, and autoload proc settings! Whooooho!
  • Aja Sales department
    June 30, 2005 at 12:35 am
    Hi-
    Any and all of the Io Control Panel settings, including ProcAmp, can be saved and recalled later.
    Under the “Presets” tab, there are controls for “Load Preset” and “Save Preset As…”. Any preset can also be set as the default, with the “Set Default” button, which once set even retains the settings if the Io is powered down and unplugged!
    So…a few of your wishes have come true 😉
    Thank you,
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
