Activity Forums VEGAS Pro New install of Vegas 80c -Media Manager destroys XP?
  • New install of Vegas 80c -Media Manager destroys XP?
    Posted by Diane Wilkins on October 22, 2008 at 2:36 am
    I just installed a new 8.0 version of Vegas as a secondary editing station on a new Dell Optiplex 755 Core 2 Duo with 4g RAM (XP Pro-2), then updated to 8.0c via the web. I then installed the Media Manager from the CD (it seemed like something I needed) where I ran into some problems. It showed (much like the Vegas install) that I had to download some components from Microsoft, so I proceeded. An error (something like, unable to install downloaded file, so I exited out. I believe it contained “MSSQL” in the name, which I have seen on another posting related to Vegas not starting, but no OS issue like I now have. After dinner, I returned to the computer to awaken it from hibernation, only to see it not boot back up. I could only go as far as the blue Windows XP Welcome screen that comes up just before the desktop. Frozen. I spent all day trying to boot up – in safe mode, command prompt. Every attempt: same result. Could not get C prompt. Where’s DOS when you need it? I can’t do any ‘repair’ since I can’t get into services or registry…
    Has this happened to anyone? Any thoughts?
    Diane
    John Rofrano replied 17 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    October 22, 2008 at 11:55 am
    A failed installation is never a good thing and yes, I have been in this situation where installing an application has caused my PC not to boot. Not a good feeling.
    I have my PC set up with an extra drive (D:) that I place all of my stock media and a daily backup of my C: drive using Acronis TrueImage. It does a full backup once a month and runs every morning at 7:30am to do an incremental backup of any changes from the day before. If a catastrophe strikes, I can boot with the repair CD and restore my computer to the state it was that morning or any day I’d like in about 20 minutes (and I’ve had to do this twice!). Once bitten, twice shy as they say. You may want to consider this a lesson learned and set yourself up like I did. It is set-and-forget easy and, as I said, has saved me several times.
    If I were you I would boot with the original Windows XP CD and do a repair install. That is not the same as using the recovery console. What you do is proceed as if you are re-installing Windows and then right after you accept the license agreement Windows recognizes that it’s already installed and asks if you want to repair the install or install fresh. Select repair the install and it will proceed to reinstall Windows over what you have leaving all of your applications in place. I’ve done this several times to recover from the problem you are having (that was before I started my daily backups which are much quicker to recover from)
    Here is a web site that describes the process in more detail. It is worth of a bookmark! 😉
    How to Perform a Windows XP Repair Install
    Good Luck!
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Diane Wilkins
    October 22, 2008 at 1:58 pm
    Thanks John – I will do that, and look into Acronis. I have heard of that. So do you use the Media Manager?
    Cheers,
    Diane
    http://www.DianeWilkinsProductions.com
    Ed*t 6.5 Targa 3K
  • John Rofrano
    October 22, 2008 at 6:41 pm
    lol, yea… I’m the trainer in VASST Absolute Training for Vegas+DVD, Vol. 7 Media Manager Demystified. I use it to keep track of all my stock media (video, audio, images, motion backgrounds, sound fx, etc.) It is an outstanding tool that is often under utilized and misunderstood.
    ~jr
