Activity Forums Apple Final Cut Pro Legacy New info on AVC intra native vs Prores?
  • New info on AVC intra native vs Prores?
    Posted by Harry Pallenberg on October 12, 2010 at 11:51 pm
    I did search on here and other boards, I did read various threads… but answers seem to change often, and I’d like to focus on the footage not the tech – so is there any new info on which is better to edit… AVC-intra 100 (1080 / 24P) as native or in the log & transfer choose Prores or ProresHQ.
    All I care about is final picture quality, render times (there will be lots of layers & FX), and playing nicely with the general post world (color correcting, mix and so on). I imagine it will be mastered to HDCAM when all said & done.
    Harry
    Allan Buchanan replied 15 years, 11 months ago 6 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    October 13, 2010 at 12:23 am
    There’s no difference as far as we can tell. AVC-Intra edits in a ProRes timeline anyway. We bring all AVC-I footage in natively.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
    Blog Twitter Facebook
  • Michael Gissing
    October 13, 2010 at 12:56 am
    ProRes might minimise render times in complicated projects but also take up more space and L&T time. One thing that Gary Adcock has been saying here for a long time is that ProRes422(HQ) is not necessary for frame sizes up to 1920 x 1080 and in fact may cause issues apart from bigger files and higher data rates needing faster drives.
    Both Walter and Shane Ross recommend ProRes timelines for complicated sequences that include long GOP native codecs and lots of graphics elements. As someone who grades and onlines I can say that I have not had issues with simple long GOP timelines going through Color (1.5.3) so it boils down to what works best in the edit.
  • Shane Ross
    October 13, 2010 at 12:59 am
    If you want the best interoperability with other systems, and LIMITED render times…bring it is as ProRes. AVCintra does not have sequence settings, so you need to use ProRes anyway. And if you use AVCI in a prores sequence, you need to render right away (well…green render so not really). Coming in ProRes on a ProRes timeline means zero render bar.
    And this means that you can share the ProRes file with ANYONE. AVCIntra requires a driver be installed.
    Personally, I’d import as ProRes to keep things simple. And it will look fine…match exactly what you see natively.
    Shane
  • Jeremy Garchow
    October 13, 2010 at 2:41 am
    AVC-Intra is not long GOP, acutally the opposite. It’s CBR constant frame.
    I edit AVC-I native all the time, but then again I don’t log and transfer (I edit uisng the MXF files). It saves oodles of time and disk space as I don’t have transcode eveyr single frame before editing, even if the timline has to render. It’s still samller than making evey single piece of your footage ProRes. I usually finish in Color and at that point render out ProResHQ. if for whatever reason you need to bounce a file out to AVC-I, MXF4mac has an AVC-I encoder.
    Jeremy
  • Harry Pallenberg
    October 13, 2010 at 3:18 am
    Thanks – everyone. I also just got an email from a friend at a big post house in Hollywood – he suggested I import as Prores
    for the savings in render time as well (at the cost of longer log & transfer – but thats 1 night per shoot of thinking – not endless rendering
    as I go). He also agreed about the prores vs prores HQ.
    THANKS again.
    Harry
    Forum Cowmunity Leader: Indie & Doc
    Forum Cowmunity Leader: HDV
    Dual 1.8 G5 ** 2GB ** 10.5.4 (Office / Photoshop)
    Dual 2.0 G5 ** 4GB ** 10.5.4 Kona 2 (FCP 6.0.4 Machine)
    http://www.womeninboxes.com
    The Documentary Film about Magic’s Better Half.
  • Jeremy Garchow
    October 13, 2010 at 3:43 am
    You’re going to need an Intel machine for Avc-I ingest.
    Jeremy
  • Allan Buchanan
    October 25, 2010 at 4:52 pm
    Hello,
    I just read you string on AVC intra versus Prores. I was under the impression that the FCP would import AVC and work natively so that ties with what you are stating. The considerations to the best of my knowledge on a long form project would be a fast processor i.e 8 core with a good amont of RAM.
    I have a shared storage solution 10TB via gigabit ethernet connection that is setup between two off FCP systems running version 7.0.
    Does this sound feasible to you?
    Many Thanks,
    Allan
