Activity Forums Apple Final Cut Pro Legacy New iMac specs suggestions
  • New iMac specs suggestions
    Posted by Christina Coppola on November 26, 2010 at 3:49 am
    Hello All!
    I am going to purchase a new iMac tomorrow so that I can upgrade to Final Cut 7. As I am not that technical when it comes to figuring out the right specs for my editing and animation needs…. I am asking for suggestions. What would be the appropriate technical specifications to order (memory, processor, etc.)
    Any thoughts would be greatly appreciated!
    Christina Coppola replied 15 years, 9 months ago 2 Members · 2 Replies
  • Jim Glickert
    November 28, 2010 at 1:47 am
    Hi Christina. I ordered a new iMac just yesterday. The specs are close to top-of-the-line for the iMac. However, I must say that this iMac will not be my primary computer for FCP (I currently use a MacBook Pro), even though I spec’d it out such that it would be hefty enough to do some FCP/Motion/Compressor/etc. duty on occasion. The lack of eSATA is a real bummer. (Yes, I’m aware of the Other World Computing option, but I’ll see how it goes with only FW800 for a while.)
    MAC 27″ $2,598.00
    PROCESSOR: 2.93GHZ QUAD-CORE i7
    MEMORY: 8 GB 1333MHZ DDR3 SDRAM
    HARD DRIVE: 2TB SERIAL ATA DRIVE
    GRAPHICS: ATI RADEON HD 5750 1GB GDDR5
    If I were buying a Mac Pro, which would obviously become my primary FCP machine, I’d probably go with 12 or 16 GB of RAM.
    I considered spec’ing just 4 GB of memory (standard) and a 1 TB hard drive and replacing both with more after-market memory and a higher-capacity drive, but I figured I wouldn’t save a whole lot of money, and I didn’t want to hassle with it. You might find it worth doing so, however.
    Hope this helps.
    Jim
  • Christina Coppola
    November 28, 2010 at 2:48 am
    Thanks so much for your input! I appreciate it1
