Activity Forums Apple Final Cut Pro Legacy new iMac QUAD-CORE & FCP2/3 – Strong enough?
  • new iMac QUAD-CORE & FCP2/3 – Strong enough?
    Posted by Aviv Vana on November 19, 2009 at 10:19 am
    Ok – the question of the day,
    the new 27″ imac Quad-Core i7 (hyper threading) – 512mb graphics card & 4-8GB RAM . . .
    This seems like a pretty good setup to work with HDV from the xh-a1 and Canon 7d/5d.
    Am i correct?
    I know i will be limited to a FW-800 and not have internal RAID.
    But this should be a HUGE step up from my current 2GHz duo-core 2 GB Ram macbook pro correct?
    My main questions is how quick will the editing be in FCP when applying effects like Magic Bullet, Twixtor, idustrial revolution’s volumetrix transitions etc etc – will the time line go RED? if so will it take a while to render so I can watch in SafeRT? Is this computer more then competent?
    Oh ya, and of course, is 2.8GHz i7 hyper-threading worth the $200 over the 2.66GHz i5? i understood that the i7 hyper-threading gives you 8-cores “virtually”,instead of 4 (whatever that means) I have no idea with what that will be applicable – the hyper-threading on an i7. Will render times be twice as fast on export with hyper-threading?
    Thank You for the guidance! love these forums
    ps – yes i know a mac pro will allow me to add black magic card (and things of the like), internal raids, esata etc etc . . . this is stuff i’m hoping to survive with for now and step up to as my business grows – heck i’ve survived and built a decent business on a macbook pro for the past 3.5 years 🙂 with a graphics card that is 128mb! and 1.5GB RAM (i was a newbie then, had no idea!)
    MacBook Pro 2.0GHz – 2GB Ram
    AE CS3, FCP Studio 2, Adobe CS3 suite
    Canon XH-A1 (soon Canon 7d/5d)
    Rick Fetters replied 16 years, 9 months ago 5 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    November 19, 2009 at 12:48 pm
    [Aviv Vana] “My main questions is how quick will the editing be in FCP when applying effects like Magic Bullet, Twixtor, idustrial revolution’s volumetrix transitions etc etc – will the time line go RED? if so will it take a while to render so I can watch in SafeRT? Is this computer more then competent?”
    Pretty much all of those types of filters will require renders. How long of a render depends on the filter itself.
    [Aviv Vana] “Thank You for the guidance! love these forums”
    There have multiple threads already about the 27″ iMac, especially right after it was announced. You’ll find many more opinions in those threads.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Aviv Vana
    November 19, 2009 at 2:04 pm
    I got an answer from Walter himself 🙂 what an honor!
    Walter, would you get the new iMac quad-core? If you were shooting with an xh-a1 and 5d/7d? and planned to do some green screening!?!?
    If so would you go with the i5 or i7?
  • Zane Barker
    November 19, 2009 at 4:23 pm
    Aviv have you looked at the benchmarks on the new iMacs?
    https://osxdaily.com/2009/11/17/imac-27-core-i5-and-i7-models-benchmarks-are-very-impressive/
    If you have looked at them then you would see what a big difference the i7 has over the i5, so in my opinion over which one to get if you had a choice, its the i7.
    [Aviv Vana] “I know i will be limited to a FW-800 and not have internal RAID”
    I’m glad you understand that, so many people don’t, and knowing is half the battle.
    I would actually recommend using a gigabit ethernet external raid over using firewire hard drives. a 2 drive gigabit ethernet raid is just about as fast as a 2 drive esata raid. And it would be cheep to put together.
    https://www.newegg.com/Product/Product.aspx?Item=N82E16822155009
    Just add drives.
    Using a gigabit ethernet raid also frees up the firewire bus so that there are no interference when capturing from a camera or deck. But it also lets you connect a AJA IO HD
    https://www.aja.com/products/io/io-hd.php
    I hope these things have given you something to think about.
    I myself plan on getting an i7.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Aviv Vana
    November 19, 2009 at 5:11 pm
    Zane,
    Thanks for the good info!
    About the gigabyte ethernet RAID, how does that work exactly when you want to also be connected to the internet through that connection?
    I’ve never used the ethernet connection for anything other than internet.
  • Zane Barker
    November 19, 2009 at 5:18 pm
    [Aviv Vana] “About the gigabyte ethernet RAID, how does that work exactly when you want to also be connected to the internet through that connection? “
    Just use a gigabit ethernet hub/switch.
  • Ben Scott
    November 20, 2009 at 1:27 pm
    was wondering if anyone has much experience with ethernet based RAID disks for reliable data throughput
    found this and thought it may be useful
    https://www.promise.com/product/product_detail_eng.asp?product_id=211
    Ethernet based RAID drive from promise
    if you were wanting to online with this imac, ethernet disk and AJA ioHD would it work day in day out is really the question?
  • Rick Fetters
    November 20, 2009 at 6:15 pm
    I have been looking into this as well, here is what I have found so far.
    1) gigabit ethernet has a 125MB/s maximum transfer speed
    2) FW800 has ~80MB/s transfer speed
    3) I researched HDD/Raid enclosures that included a gigabit ethernet port and looked for reviews/test of transfer speeds. The fastest ones I could find that were less than $500 for the enclosure (bare, no drives) didn’t have impressive transfer speeds i.e. 350mb/s max, most in the 275mg/s range (this is only 40MB/s or half of FW800).
    I am still doing research and definitely might be missing something. I see it as a reasonably good solution if the speeds matched or bettered FW800, but it isn’t looking promising.
    rick
  • Ben Scott
    November 20, 2009 at 7:03 pm
    Not sure if simple enclosures get near to the larger data rates
    think something like final share is needed e.g. Iscsi type solution which is more pricey
    most cheaper nas boxes I looked at this afternoon appear to work a bit slow for more than a single track of video in a compressed format
  • Rick Fetters
    November 20, 2009 at 7:14 pm
    I looked over the NS4600 literature on their website and couldn’t find any mention of transfer speeds so I called their technical support line. I spoke with human after a relatively short 5 minute wait. He said that is is max 40MB/s read and 30MB/s write for the NS4600. Again, this is pretty slow and not really useful for heavy editing work.
    rick
