Activity Forums Apple Final Cut Pro Legacy New Hard Drive problem, does not have read/write access
  • New Hard Drive problem, does not have read/write access
    Posted by Mccaincow on December 23, 2005 at 2:22 pm
    I just purchased a dual 2.3 G5. I had a Lacie firewire drive crash again, so I went out and purchased a Hitachi 400 GB internal drive and installed it in the second bay. I copied all of the files from my previous drive. Now however when I load Final Cut I get the error message “The thumbnail cache File Folder dose not have read/write access, please select a new folder in the system settings dialog or correct the problem on the disk”. When I try to copy files to the disk sometimes it ask me to authenticate and others it does not. I can not save to this drive. Anyone know what could be going on here?
    Mccaincow replied 20 years, 8 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    December 23, 2005 at 2:51 pm
    Sounds like it’s permissions need to be looked at. Select it on the desktop, but not open it… then type cmd+i to Get Info on it. Change the permissions to read and write, and you should be good to go. Make sure it’s formatted to be mac OS Extended. I don’t think it matters if it’s journalled or not.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mccaincow
    December 23, 2005 at 3:02 pm
    Somehow when I copied the folders off of the firewire drive, all of the folders were set to read only. I have to go to “get info” and change them one by one to read and write and now everything is working fine
