Activity Forums Adobe Premiere Pro New from FCP – lingering quick questions for huge time savers
  • New from FCP – lingering quick questions for huge time savers
    Posted by Heather Brown on February 19, 2013 at 10:33 pm
    Questions that I can’t seem to figure out, or hope there are new answers to:
    1. Is there anyway to view duplicate frames within the sequence? (not just in the preview stating how many times it’s been used) I’m looking more for a visual warning. So key in the videos that I edit.
    2. Is there a way to show out of sync, without the video & audio linked? …or am I just forced to keep the files linked as default?
    3. Is there any way to double click on a clip in the sequence & have the playhead appear in the source in the current spot on the clip? Seems to work the first time, but then always in the same place if the clip is double clicked again w/ the playhead in a different place later.
    4. Is there way to keep the folder structure of imports if folders are within folders? I know you can import folders if they don’t have any other folders within them…but folder within folders don’t keep the same structure.
    5. I would like to highlight a clip in the sequence, hit +10 and for it to move 10frames over. How do I do this? I know I can zoom in, deselect the snap and pull it over AND I know that I can move the playhead & snap to it, but both are not as efficient as what I’m used to.
    Kevin Monahan replied 13 years, 6 months ago 2 Members · 1 Reply
  • Kevin Monahan
    February 20, 2013 at 12:45 am
    [Heather Brown] “1. Is there anyway to view duplicate frames within the sequence? (not just in the preview stating how many times it’s been used) I’m looking more for a visual warning. So key in the videos that I edit.”
    No, that would be a feature request: https://www.adobe.com/go/wish
    [Heather Brown] “2. Is there a way to show out of sync, without the video & audio linked? …or am I just forced to keep the files linked as default? “
    [Heather Brown] “3. Is there any way to double click on a clip in the sequence & have the playhead appear in the source in the current spot on the clip? Seems to work the first time, but then always in the same place if the clip is double clicked again w/ the playhead in a different place later. “
    No, that would probably be a bug: https://www.adobe.com/go/wish
    You can try Sequence > Match Frame and see if that works, though.
    [Heather Brown] “4. Is there way to keep the folder structure of imports if folders are within folders? I know you can import folders if they don’t have any other folders within them…but folder within folders don’t keep the same structure.”
    [Heather Brown] “5. I would like to highlight a clip in the sequence, hit +10 and for it to move 10frames over. How do I do this? I know I can zoom in, deselect the snap and pull it over AND I know that I can move the playhead & snap to it, but both are not as efficient as what I’m used to.”
    Use the Numeric Keypad not the numbers on the top of the keyboard.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
