Activity › Forums › Apple Final Cut Pro Legacy › New Flash problem
  • David Roth weiss
    November 14, 2010 at 8:30 pm
    What are you using to play this back with??? Use MPEG Streamclip or one of the Flash players if you’re trying to use QT Player.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Al Davis
    November 14, 2010 at 9:56 pm
    Chris,
    When you encode to H.264; you need to set the audio to AAC.
    It defaults out of FCP to Linear PCM.
    This is a common mistake, and easy to fix.
    BTW – you technically don’t even have to change the file to .flv; but perhaps your client will feel better if you do. Flash players easily read h.264(.mov).
    All the best,
    -Al
    Al Davis
    Visual Velocity
    Brookline, MA
  • Chris Baker
    November 15, 2010 at 8:17 pm
    Thanks all. I will change the audio and see how that works. I still find it odd that the original file plays fine then when you change the extention it won’t play the audio in the Flash Player. Yet it I change the extention back it plays fine in Quicktime. Doesn’t make sense to me.
    Visit us at;
    http://www.frogpondproductions.biz
    (860)884-6015
    The creative urge is the demon that will not accept anything second rate.
    -Agnes DeMille
