Activity › Forums › Panasonic Cameras › New Firmware Update 1.21
Posted by Guy Mcloughlin on October 26, 2010 at 5:36 pmPanasonic has released a new firmware update that significantly reduces the amount of image noise with the HMC-150, so it’s definitely worth updating your camera:
Guy Mcloughlin replied 15 years, 10 months ago 3 Members · 11 Replies -
John Baldino
November 2, 2010 at 1:09 pmGreat help. Thanks for sharing.
John Baldino
Director/DP/Editor
GoboMedia, LLC
john@gobomedia.net
http://www.gobomedia.net (under construction)“Philosophy is questioning without answers; religion is answers without questioning.” – Anonymous
John Baldino
November 2, 2010 at 1:37 pmFollow up —
I did the upgrade but I am having trouble finding any literature from panasonic that verifies the noise reduction. Barry Green’s DVXuser forum seems to concur that this was not a posted benefit.
Were you able to do any before/after tests? I’d be curious to see if this is something demonstrable. And if so, curious why Panasonic didn’t mention it at all in the pdf…
John Baldino
Director/DP/Editor
GoboMedia, LLC
john@gobomedia.net
Guy Mcloughlin
November 2, 2010 at 7:49 pmThe info from Panasonic is kind of obscure, in that they state “improved recoder”, and nothing much else. ( I strongly suspect that “improved recoder” is actually “improved encoder” )
Reading Barry’s posts on DVXUser, it doesn’t appear that Barry has done any testing yet, so he is skeptical of any improvement. But one member of DVXUser posted non-scientific before and after screen grabs that appeared to show a difference with noise in darker areas of the image.
I shot a bunch of interviews last Friday with the new firmware, but haven’t had time to look at them yet, and probably won’t be able to get to them until next week. ( too much on my plate right now )
I can’t imagine Panasonic releasing a new firmware unless there was some obvious benefit to the end users.
I am also going to check audio recording, as audio noise is the one area that I’m not too happy about the HMC-150’s performance. ( it’s always been about 10 – 15 dB noisier than my other cameras, including some high end consumer video cameras )
Al Bergstein
November 9, 2010 at 7:22 pmI have gone to a field mixer to eliminate the audio noise. The Mixpre has helped get it to where it should be, which is almost nil.
It is sad that Panny put such crappy preamps in the 150. Does anyone know how it stacks up to higher end Panny cameras? Or even lower end ones?
Alf
Guy Mcloughlin
November 9, 2010 at 8:13 pmI also use a Sound Devices MixPre to both power and amplify my condenser mics, which helps a bit, but the real problem is not the HMC-150 pre-amps which are actually pretty good, but rather the noisy audio circuitry of the camera which is about 10-15 dB noiser than the best consumer cameras, and worse compared to other prosumer cameras.
If you want to get real “motion picture” quality sound ( better than the 48 dB that the HMC-150 records ), you need to add a good digital recorder to mix. I use the Olympus LS-10 which records audio from the Tape-Return socket on the MixPre field mixer. The Sony PCM-M10 is another great little digital recorder with a dynamic range of 80+ dB. ( 30 dB MORE than the HMC-150 records )
Al Bergstein
November 9, 2010 at 9:32 pmNot sure what you have read that show that the pre-amps are good vs noisy audio circuitry. Is there something that actually tests that, that you have seen? Anyway, I also do occasionally go into a Zoom H4n off the mixpre which has been great.
Neither the Zoom nor the Olympus LS-10 are ‘motion picture’ quality sound. To get that, you need to spend a lot more money, thousands more. These are prosumer products, low end industrial quality at best. They have their own set of issues, like harshness, compared to top quality gear. But for my client needs, they are fine. There are great reviews out there that clearly demonstrate their limitations, which I read when investigating which ones to buy.
Here’s an example of some solid testing between the Zoom and the Edirol, which is considered a “professional” level field recorder.
https://www.martin-doppelbauer.de/fieldrecorder/
and especially read this…a great test..harmonic distortions in recorders…
https://www.martin-doppelbauer.de/fieldrecorder/distortions.html
Zoom, Sony and Olympus which we are discussing are good alternatives to the native sound quality of the HMC-150, which for most situations is fine, but for quiet rooms, and interviews done in quiet rooms is just not up to the task, from my experiences. But these are not ‘professional’ level tools.
Alf
Guy Mcloughlin
November 9, 2010 at 10:16 pmNot>>> Sure what you have read that show that the pre-amps are good vs noisy audio circuitry
I say this because I can record pretty much the same noise levels whether I’m using my Sound Devices MixPre or the built-in HMC-150 pre-amps. If the noise was only caused by crappy camera pre-amps, then I should see a big drop in the noise-floor when I switch to the Sound Devices pre-amps, but I don’t. Both are noisy compared to the consumer cams I use ( Canon HG21, Canon HV30, Panasonic HS700 ) and my old DVX-100 camera, all show a noise floor about 15+ dB lower than the HMC-150.
To achieve what I would consider “motion picture” sound ( for lack of a better word ) you still need to use professional mixers and professional mics that are designed for this type of work, and have an expert sound people operating during the shoot.
Provided a good LINE-LEVEL professional audio signal, the Olympus LS-10 or the Sony PCM-M10 can record outstanding audio. 96 KHz @24 bit sampling and a flat frequency range from 20-20KHz, with very low distortion. ( you don’t use the built-in mics, you don’t use the built-in pre-amps, you only use the DA converters to record the audio signal as HQ audio files )
Without professional mics and mixers then you might as well just record straight in to the HMC-150, as low cost audio gear will never give you this type of sound.
I’ve seen the Martin Doppelbauer tests and would never by any Zoom product. ( I’ve owned a few Zoom units briefly, but all of them had problems which I would not put up with )
I agree with you when it comes to the Zoom products, but completely disagree when ONLY using the LINE-LEVEL record features of the Olympus and Sony compact recorders. They are great recorders, but you have to use professional mics and professional mixers to feed them a high quality audio signal. ( BTW, the MixPre is a very good mixer, very low noise levels and very good pre-amps, but you won’t hear this without a recorder that can properly record it’s signal )
Al Bergstein
November 9, 2010 at 10:31 pmGreat post. Thanks for that feedback. But I did see a drop in noise when I simply added the Mixpre to the chain, taking the mics that I was feeding in to the mixpre first.
I forgot to mention that I also don’t use the built in mics of the Zoom H4n. It has worked well for me though, by staying with external high quality mics and feeding it from the MixPre.
Alf
Guy Mcloughlin
November 9, 2010 at 11:43 pm>>>But I did see a drop in noise when I simply added the Mixpre to the chain, taking the mics that I was feeding in to the mixpre first.
What was the change in dB ?
I used Sony Sound Forge 9 to measure the audio levels, and did not see much difference. ( I’m using AudioTechnica 4053B and 3031 condenser pencil mics along with Sanken COS-11x lav mics and Sound Devices mixers: MixPre and 302 )
Al Bergstein
November 10, 2010 at 12:06 amI don’t remember, as this was months ago, when I bought the Mixpre. When I get some downtime (December???) I’ll see if I can do a thorough measurement. I certainly could have been off somewhere…But I’ll check.
Alf
