Activity Forums Avid Media Composer New Error Message
  • New Error Message
    Posted by Sam Pope on September 21, 2006 at 10:36 pm
    got kind of a long story here. if anyone is able to help, please keep in mind that i’m fairly new to avid…
    and i’m using avid express pro hd.
    so the whole problem start with this error message that would keep popping up, usually when i was shutting down avid: Exception: omfiHPDomain_INIT_Failed,file;msmMMOB.mdb
    Exception: omfiHPDomain_Bad_Magic
    when i would reopen the project, anything new that i had created or imported, would be offline.
    i read through a couple of forums and got the information that i should go in a delete the offending msmMMOB.mdb files, which i did. now, when i open avid and the project in avid that i am working on, it comes up with this message Exception: unsupported resolution. all of the clips are there and it lets you scroll through the timeline, but when you try to play it, that error message comes up…
    i had the project backed-up on an external drive, so i brought that back in and it still comes up with the error message. if i open other project in avid, they work fine…
    any help would be GREATLY appreciated.
    Don Logan replied 19 years, 11 months ago 2 Members · 1 Reply
  • Don Logan
    September 24, 2006 at 6:03 pm
    try going into your media creation setting in the project window under settings. you might be filtering by resolution. ‘Exception: unsupported resolution’ Also were all of the files/clips created on express?
