Activity › Forums › Blackmagic Design › New Driver (5.7.2), digitizing SD 16:9 Widescreen is 4:3 AVI, same
Posted by Martin on October 11, 2006 at 10:35 amAndrew Mcleod replied 19 years, 11 months ago 3 Members · 7 Replies -
Martin
October 11, 2006 at 10:42 amSorry I pressed enter to early 😉
Digitizing a video with Premiere Pro 2 during a selected 16:9 widescreen PAL SD project and driver 5.7.2 creates like the old driver 5.7.1 an AVI with 4:3 aspect ratio.
This AVI will display in the same widescreen project in Premiere Pro in 4:3 and not in 16:9. Premiere Pro 2 with BM-driver 5.6 shows the AVI correct in 16:9 widescreen. -
Andrew Mcleod
October 12, 2006 at 4:41 amHi
Thank you for reporting this bug. We have logged it and are currently looking into this issue.
We should have an update available shortly.
Any other issues – please email pcsupport@blackmagic-design.com
Andrew Mcleod
October 12, 2006 at 7:16 amDecklink 5.7 does not appear to be affected by this issue and is recommended.
It is available for downloadd from the archive.
https://www.blackmagic-design.com/support/software/archive/ -
Martin
October 12, 2006 at 8:57 amHi,
I tried this version…Same bug as in versions 5.7.1 and 5.7.2
Luke Maslen
October 12, 2006 at 12:43 pmHi Martin,
It looks like we should be able to fix this in the next driver update which will coincide with the release of the new Intensity card towards the end of this month so it’s not far away.
Regards,
Luke Maslen
Blackmagic Design
