Activity › Forums › DaVinci Resolve › New DaVinci Resolve panel menu guides
Posted by Peter Chamberlain on January 13, 2011 at 2:24 amHi guys, there are new Tangent Devices Wave, and JL Cooper Eclipse panel menu guides on the BMD DaVinci support site.
Both relate to the just released v7.1.
https://www.blackmagic-design.com/davinci/support/
regards
PeterJay Moffat replied 15 years, 7 months ago 7 Members · 6 Replies -
Vladimir Kucherov
January 13, 2011 at 3:31 amAh, this tidbit seems to shed light on something that was mentioned in a previous thread:
“each Trackball and Master level set has two reset buttons.
The ring button will reset all.
The dot button will reset the RGB values.
selecting alt, then the dot button will level all the values”I’m really happy with the new configuration though! I can now move more common items off the G13 and replace them with lesser used items
Luis Otero
January 13, 2011 at 4:46 amThanks a lot! I am in the middle of a big project, and the change has slowed me down since I am re-learning the new configuration. This guide should help a lot…
Luis
Ola Haldor voll
January 13, 2011 at 7:21 amGreat stuff, Peter. Will become very handy whenever I get my hands on the Cooper!
Sascha Haber
January 13, 2011 at 7:26 amThanks a lot for the new guide.
I am still a little confused what exactly the curves high clip and soft clip do and curves itself move with the Wave.
But still the reset function is my biggest thing.
If I change a balance with the balls, then afterward use the ring to slightly lower or raise the values all together, I have a hard ime to get rid of that change.
I wonder if it would be possible to add that function to ALT+ring.
Pressing ALT+dot (level ?) seems to move the balance really out of space for me.
Or maybe I am just not used to it the way it works.
When i move the ring, the Luma slider moves, and RGB moves accordingly.
When I do the same with the mouse on the slider only, it moves, but nothing happens.
The way I would expect it :
The ring changes all the values up and down.
Reset the ring moves all the sliders to their positions before the ring adjustments.
That would be it.A slice of color…
DaVinci 7.1 OSX 10.6.6
Dual Xeon 2,4 RAM 24 GB
RAID0 8TB eSata 6TB
GTX 285 / GT 120
Extreme 3D+ WAVE -
Illya Laney
January 13, 2011 at 4:53 pm“When I do the same with the mouse on the slider only, it moves, but nothing happens.
The way I would expect it”It sounds like you’re adjusting the luminance only. Middle click will allow you to raise and lower YRGB all equally. To see what the clip adjustments do, just check out a parade scope while messing around with it and you’ll see. Just think of it as “smoothing out” or “rounding off” where you set the high and low clip points.
twitter.com/illyalaney
Jay Moffat
February 20, 2011 at 2:07 pmHi Peter, are there plans to include the Eclipse Bridge to the config?
Thanks…
J
