…Plenty of the new features are clearly intended for pros only — the 64-bit memory support, Auditioning, metadata organizing, resolution independence, color matching and so on…
Yes 64bit memory is great! Auditioning…frankly I don’t know what that is. “Metadata Organizing”??? Are they crazy. Shots are organized by Scene/Shot/Take numbers not People, one person/two people, Factories,etc. I’d never get an assembly done if I had things labeled like that. I only work in one codec then transcode if needed(rarely-but I know other people who appreciate this function). Color matching – I’m not a colorist. That’s a talent all in itself, like a composer. I dabble with color but when the rubber hits the pavement I leave that to the pros.
