Activity Forums AJA Video Systems new control panel / io stand alone
  • new control panel / io stand alone
    Posted by Chris Paul on May 6, 2005 at 3:06 pm
    Hey you users of the new control panel that lets io convert from analog to serial digital as a stand alone device-
    I’d like to use it in conjunction with K2 to get betacam into that card. My question: does it have the 1 frame delay that many external converters have?
    While i’m asking… is anyone using this setup to take advantage of K2’s real time HD upconvert?
    Chris
    Chris Paul
    POV
    Dave Jenkins replied 21 years, 2 months ago 3 Members · 2 Replies
  • Aja Sales department
    May 6, 2005 at 11:38 pm
    Hi-
    Yes, there is a 1-frame delay when going through the Io in it’s Control Panel stand-alone frame-sync mode. There is a simple setting in FCP when using with the Kona 2 to digitze from the SDI signal coming from the Io:
    – go to “Audio/Video Settings” in Final Cut Pro HD pulldown
    – choose “Device Control Preset” tab
    – click “edit” to modify the device control parameters of the Easy Set-up you are using
    – need to reduce the Capture Offset by -1. For example, the Sony default is -3, so you would simply make it -4.
    Now you have a frame-accurate preset, taking into account the delay form the external conversion.
    Call us if you have any questions! (530) 274-2048.
    Thank you,
    AJA Video Systems
  • Dave Jenkins
    May 7, 2005 at 7:06 pm
    I want to personally thank you for posting here. It’s nice to have an AJA presence on the board. Very few companies do this.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO
    Huge 1.2 Raid
    FCP 4.5-OS X 10.3.5-QT 6.5
