Activity Forums Adobe After Effects New composition setting change
  • New composition setting change
    Posted by Areful Eeslam on March 13, 2012 at 9:22 am
    Hello, im using CS 5.5. By default the new composition duration window calculating input value by frame not seconds. I dont want to sound blunt so im putting a pic here.
    How can i change the duration input format into seconds? It might be simple but it’s not in the preference menu. Please help me.
    Awaiting reply….
    Regards
    Areful Eeslam replied 14 years, 6 months ago 2 Members · 2 Replies
  • John Cuevas
    March 13, 2012 at 11:51 am
    Create your new composition with the proper settings(save for how it counts frames) and click “OK”. Now in your timeline in the upper left corner you will see the current frame, “Cntl” + click it and it will change to display timecode.
    Now when you create a new comp it will default to displaying timecode rather than frame counter.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Areful Eeslam
    March 13, 2012 at 12:31 pm
    Thank you very much Johnny….
