Activity Forums Adobe After Effects “New Composition from Selection” with Sequence Layers – frame base seems stuck at 30 fps?
  • “New Composition from Selection” with Sequence Layers – frame base seems stuck at 30 fps?
    Posted by Declan Zimmermann on January 31, 2017 at 5:06 am
    My subject line kind of says it all.
    Even though all my preferences are set to 24 fps, even though the most recent new composition I created was 24 fps, when I use the “New Composition From Selection” feature with sequence layers and enter a time for the layer, it says “base 30.”
    If I enter 2 frames, I get a 24 fps composition but the layers are a bit less than 2 frames (presumably 1/15 of a second at 24 fps.)
    This is a bit maddening. Anyone know how to get this feature to just work in base 24 fps?
    Declan Zimmermann
    Design & Motion
    motiongraphicsnyc.com
    twitter: @MographNYC
    Luiz paulo Iazzetti santos replied 5 years ago 2 Members · 1 Reply
  • Luiz paulo Iazzetti santos
    August 24, 2021 at 1:49 pm
    Welll, the world has changed a lot since your question. But you can set time base settings on File>Project Settings>Time Display Style tab – “default Base” setting.
    Hope you’re fine!
    Best
    Lp
