Activity Forums Blackmagic Design New comer to Decklink
  • New comer to Decklink
    Posted by Sean Davison on November 15, 2005 at 9:19 am
    Hi – Just got a DL HD Pro and a Multi Bridge
    I’ve got the Monitor hooked up direct to the card (no Multibridge) via YUV. I’ve re installed FCP 5 and updated it to 5.0.3 and Ive run all the latest updaters drom the decklink site. The card is not outputting anything. It flashes on start up but that’s it. Im running a G5 dual with 2gb Ram runningh OSX 10.4.3. I have got Automatic duck installed. Deck control doesnt output anything either.
    I’ve had to get a new system as my Cinewave has died mid job – I’m due to do an on line tomorrow!
    help?
    Dmitry Klischik replied 20 years, 9 months ago 4 Members · 4 Replies
  • Kaspar Kallas
    November 15, 2005 at 10:51 am
    What card are you using?
    Make sure you are outputtung the right signal from FCP (better yet use esy setup)
    try to use the (Y) composite signal to make sure the cables are OK
    if you enable the extended desktop, does it show up on your monitor?
    -Kaspar
  • Dmitry Klischik
    November 15, 2005 at 5:06 pm
    Hi!
    The same problem, absolutely. My card is Decklink SP. Guys, please help. Mayby the answer is to reinstall older drivers?
    Dmitry.
  • Kristian Lam
    November 15, 2005 at 10:28 pm
    Which model of Dual G5 do you have? Make sure it’s not the one with PCI slots as they are not supported. Kindly refer to this:
    https://blackmagic-design.com/support/detail.asp?techID=76
    regards
    Kristian
    Blackmagic Design
  • Dmitry Klischik
    November 16, 2005 at 11:16 am
    Hello!
    Yes, Kristian, you right. This is Mac with PCI slots. I’ve pu Decklink SP into PCI-X computer – evverything works fine. But here’s another question. When i connect to my broadcast monitor using composite signal ove Y-Out cable, the color of the output is fine. But when i connect to component input of my monitor using all three cables from Deckling SP the picture lacks the saturation. It looks like desaturated by 50%. Is it known issue, or i have the problems with monitor. The monitor is JVC TM-1750PN.
    Thank you,
    Dmitry.
