Activity › Forums › VEGAS Pro › New Color Curves Plug-in
  • New Color Curves Plug-in
    Posted by Marco Baer on June 2, 2019 at 3:01 pm
    There is a new Color Curves plug-in available for Vegas Pro, called Graide Color Curves. Some of its features are:
    – Curves view can be zoomed in and out and moved.
    – Switch between RGB and percentage values.
    – Optional enter values for precise adjustments (you could even isolate single RGB values).
    – Curve’s ends can be moved horizontally.
    – Copy and paste nodes.
    – Switch between Y’RGB and HSY’ curves mode.
    – In HSY’ mode you can use the curve in different dependencies (H/S to Y’, S/Y’ to H, H/Y’ to S).
    – Using a pipette you can pick single color values or color ranges which then are represented in the curve.
    – Optional Studio-RGB mode to adopt to studio swing levels.
    – Output FX gain adjustment.
    George Dean replied 7 years, 3 months ago 2 Members · 1 Reply
  • George Dean
    June 2, 2019 at 10:38 pm
    Thank You Marco for posting. That should assist some user in their color grading.
    Best Regards……George
