Activity Forums Maxon Cinema 4D New CD Morph plugin coming soon
  • New CD Morph plugin coming soon
    Posted by Cactus Dan on April 10, 2005 at 1:50 am
    Howdy,
    I have a new morphing plugin coming soon called CD Morph. It’s a point selection morphing system that does not require copies of your polygon object for the morph target shapes. The points to be morphed are stored in a morph selection tag.
    Here is an example vid of how the morph tag works:
    https://www.cactus3d.com/CDMorphBone.mov
    Here is the morph tags AM:
    There is also a Jason Osipa style Box Slider tag that can be used to drive the morphs:
    https://www.cactus3d.com/CDMBoxSlider.mov
    Here is the Box Slider’s AM:
    The box slider also has output ports for Xpresso so it can be used for any type of custom controller setups:
    CD Morph also comes with an optional Mixer to mix the morph tags in one place with all of the sliders, for those who prefer the PoseMixer type interface:
    For an example of how you set up the morphing, here is a quick tut by Mike (slouchcorp):
    https://www.slouchcorp.com/CDM/QSG.htm
    The final version of CD Morph is actually done, I just need to write the docs and then it’ll be ready for release.
    Adios,
    Cactus Dan
    Cinema 4D R9 XL Bundle, BodyPaint, Dynamics
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
    Todd Groves replied 21 years, 5 months ago 2 Members · 1 Reply
  • Todd Groves
    April 11, 2005 at 3:45 pm
    Wow. Thanks, Dan, for putting that together. It looks it will have some exciting uses.
