Activity › Forums › Adobe Premiere Pro › New Build for CS5.5 Do You See Anything Wrong With This List
  • New Build for CS5.5 Do You See Anything Wrong With This List
    Posted by Bill Zowak on May 22, 2011 at 7:00 pm
    Does anyone see a problem with the following build for new CS5.5 custom edit system?
    MB – want to use LGA 1155 Board ( Still To Be Determined) any suggestions?
    Memory – 16 gig. will determine once MB is selected
    Video – EVGA 015-P3-1580-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    CPU – Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
    Raid card – areca ARC-1222 PCIe x8 SATA / SAS (Serial Attached SCSI)
    PSU – CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply (may up it to a 1000W)
    System HD – Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5
    Raid Hard drives (possibly raid 10) – Western Digital RE4-GP WD2002FYPS 2TB 64MB Cache SATA 3.0Gb/s 3.5″
    Blu-ray Burner – SONY Black 12X BD-R 2X BD-RE 8X DVD+R 5X DVD-RAM 8X BD-ROM 8MB Cache SATA BWU-500S
    DVD Burner – ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner – Bulk – OEM
    CPU Fan – COOLER MASTER V6 GT RR-V6GT-22PK-R1 120mm DynaLoop CPU Cooler w/ Universal bracket & Dual Fan
    Any suggestions as to what LGA 1155 MB to go with? What memory is best for this config?
    Thanks for looking
    Morgan Newall replied 15 years, 2 months ago 3 Members · 4 Replies
  • Jeff Brown
    May 23, 2011 at 1:59 am
    If you can spend a little more for your system drive, I’d suggest a SSD (Solid State Disc). It will make program loading quicker; I’ve been very happy with mine on a recent build (Intel SSD; Win7pro; SuperMicro MB).
    -Jeff
  • Bill Zowak
    May 23, 2011 at 11:08 am
    Jeff,
    Thank you for your input. What model MB did you go with? As far as the SDD goes I’m not convinced of the their benefits just yet. I am a custom systems builder but I will tell you that I do not have a lot of personal experience with SSD. My main system is not as beefy as the mentioned build. I have an I7 920 with 12 gig ram. My OS drive is a WD 10000 rpm. I purchased a well rated Intel SDD out of professional curiosity. My personal findings (this was about 6 months ago) was there was no noticeable difference between the 2. Your suggestion will now make me reconsider this. The case I specked out for this build is designed for a SSD. I will search for a “to SSD or not to SSD” post. The real reason I was not looking in that direction is/was the horror stories of degrading drives, lost data, drives just failing, etc…. Has that changed? That is far more important to me then the cost. As I said, I build custom systems and have built dozens of edit systems for different platforms but I am not an arrogant know it all and would not be doing my due diligence if I did not seek the help for those that actually use the systems for editing. Again, thanks for your input. I would like to hear about what SSD you are using , how long for, and any other info you could help with.
    Appreciate the time.
    Bill
  • Jeff Brown
    May 24, 2011 at 2:31 pm
    You have more experience that I do! But, for what it’s worth, I built my current workstation about 7 months ago. The only issues with my Intel SSDs (one system, one “scratch” drive) were: having to make sure the system BIOS was set to AHCI mode on installing* (for Win 7 to recognized SSDs as such). Added the Intel management sofware, which I have set to “trim” once a week. My disc I/O in “Windows Experience Index” is 7.5. The mobo I’m using is a SuperMicro X8DAH (single i7-hex) as part of a 5046 “barebones workstation.” [nice unit, BTW].
    *in my case, I found out _after_ installing, and had to do some voodoo to switch from non-AHCI to AHCI to get the drives seen as SSD by Windows. At this point, I forgot what the ‘voodoo’ was, but I don’t remember it being too painful.
    -Jeff
  • Morgan Newall
    July 7, 2011 at 6:14 am
    Hi Bill,
    Will be building a rig myself in the short-term.
    Re: Sandy Bridge, I stumbled upon this article in my research, seems Sandy Bridge aint the way to go: https://www.videoguys.com/Blog/E/DIY+Update+Sandy+Bridge+Not+Recommended+by+Videoguys/0xe84ad86778528fd86109889b90a3d37a.aspx
    My specs at the moment (based on videoguys recommendation):
    • 16010561 X 1 – Antec Three Hundred Tower Gaming Case – No Power Supply
    • 19010199 X 1 – Intel Core i7 960 Processor
    • 28023380 X 1 – ASUS Sabertooth X58 – ATX
    • 37140806 X 1 – Corsair 12GB (3x 4GB) Vengeance DDR3 RAM
    • 42050940 X 1 – EVGA GeForce GTX 460 SE – GDDR5 1024MB 256Bit VRAM
    • 22040155 X 1 – SAMSUNG Spinpoint F3 – 1TB
    • 17040381 X 1 – Samsung 22x DVD-RW SATA
    • 34040607 X 1 – Cooler Master GX Series 750W Power Supply
    • 18010127 X 1 – Antec TriCool 120mm
    • 39090367 X 1 – Microsoft Windows 7 Ultimate – SP1 – 64-Bit
    Cheers,
    Morgan
