Activity Forums Storage & Archiving New BRU Release..sudo restore?
  • New BRU Release..sudo restore?
    Posted by Dan Olsen on March 8, 2017 at 2:18 am
    Tried running two archives on the new 3.1.23 rel and froze both times immediately upon hitting “start archive” so I thought I’d give some restores a shot–only to see this
    Never seen that before! Anyone else having the same issue? Am I doing something wrong?
    Tim Jones replied 9 years, 6 months ago 3 Members · 5 Replies
  • James Vorley
    March 8, 2017 at 4:11 pm
    Exact same behaviour here after updating.
    Verifies still working from the command line.
  • Tim Jones
    March 8, 2017 at 6:05 pm
    The team is working on this.
    Are both of you running on 10.11.6 by any chance?
    In the meantime, you can skip authenticating at the start and it will run in your user’s space. This will work unless you’re actually trying to backup and restore your system volume (which requires authentication).
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.tolisgroup.com
    BRU … because it’s the RESTORE that matters!
  • James Vorley
    March 8, 2017 at 6:20 pm
    Skipping authenticating worked a treat, thanks Tim.
    On 10.10.5 here.
    Cheers
    James
  • Dan Olsen
    March 8, 2017 at 6:56 pm
    Thanks Tim, I’m actually on 10.10.5
  • Tim Jones
    March 8, 2017 at 9:41 pm
    Hi Guys,
    3.1.23 build 357 is now posted on the download site. It was a bad header file pointing to the wrong API …
    Tim
    Tim Jones
