Activity Forums VEGAS Pro New Blue preset crashes
  • New Blue preset crashes
    Posted by Mike Hinkel on November 12, 2011 at 1:04 pm
    I have discovered that the presets made with the New Blue Titler will crash Vegas Pro 11. The second you click on the preset inside the preset window it shuts down. However, if I drag the NBT from the media generator window to the timeline I can use the dropdown to use the preset….Confused? So am I. It there a fix in the works to address this bug by either New Blue or Sony? A workaround is one thing, but having things as they should be is quite another in the workflow.
    Mike Hinkel replied 14 years, 5 months ago 3 Members · 3 Replies
  • Dave Lozinski
    November 12, 2011 at 3:33 pm
    Sony probably doesn’t care too much since it’s not their software that’s the source of things going ka-plooey.
    The NBT is supposed to be out within the next two weeks or so. Maybe by then they’ll have a fix from all the bug reports I’m sur ethey’ve received from the Vegas release.
    I guess for now all you can do is stay tuned…
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
  • Edward Troxel
    November 12, 2011 at 3:59 pm
    I have discovered that build 111013 properly created presets and you could properly use those presets. In my testing using build 111024, Vegas did not crash but it could no longer save presets. In my case it was able to recall the preset but new presets could not be saved. However, I did not add any strenuous cases to the preset testing.
    In reality, you should be using the File – Save As option to save your titles for future use. Then you can use the File – Open option in titler to recall those titles.
    Edward Troxel
    JETDV Scripts
  • Mike Hinkel
    November 12, 2011 at 5:38 pm
    Edward, either way it would certainly be much esier to use the preset from the preset window. I can see it, click on it, and done. I don’t understand the logic of the software making you go through all the extra steps to use a preset. What I really don’t understand is why the NBT crashes the host by it’s application to start. I hope those that do understand it can get the bug ironed out.
