Activity › Forums › VEGAS Pro › New Blue FX Flash Remover: Won’t eliminate flash
  • New Blue FX Flash Remover: Won’t eliminate flash
    Posted by Joseph Ptak on January 18, 2010 at 3:01 am
    I got a bunch of New Blue effects including Flash Remover. I pulled up a 12 second clip that had numerous camera flashes. I tried all 3 plugins, TYPICAL, BRIGHT, DIM, and the flash is still there after rendering to a new file. I even tweaked the settings for all three. The DIM setting barely worked but made the playback sluggish. Anyone else out there looking for a dependable flash remover?
    pcsjgp
    Edward Troxel replied 16 years, 8 months ago 2 Members · 3 Replies
  • Edward Troxel
    January 18, 2010 at 2:45 pm
    First of all, what version of the plugin are you using? You might want to download the most current version from newbluefx.com to make sure you are current. Then it should be a matter of properly adjusting the sensitivity.
    Edward Troxel
    JETDV Scripts
  • Joseph Ptak
    January 18, 2010 at 2:53 pm
    I am running Vegas Pro 9, and just downloaded the entire Essentials Suite from New Blue last week.
  • Edward Troxel
    January 18, 2010 at 3:19 pm
    For the best support, you’re better off filing a help ticket a newbluefx.com/support.html
    Edward Troxel
    JETDV Scripts
