new audio file not aligning with existing project
So we are producing a music video in FCP, synchronizing multiple clips with an audio file. After several days of work, we are pretty much done, but I just received the mastered version of the song.
We thought we would easily be able to replace the audio file we had been using in the timeline with the mastered version, since they line up perfectly with each other. To our dismay, when we dragged it into the project, there was slight latency, or a delay, which increased gradually over the course of the song. In fact, if we drag in a copy of the same audio file we used to make the video, it won’t line up with the project.
The audio files have the standard 44kHz sample rate, while the sample rate in FCP is set to 48kHz. Changing it to 44kHz at this point doesn’t help.
Is there any way to get the new file to line up with the project? Otherwise we will have to start from scratch. Any insight or guidance on this subject will be appreciated!
